Valve Spring Question
Old Mar 17, 2021 | 12:05 AM
robert3elizondo's Avatar
robert3elizondo
Default Valve Spring Question
I bought a 2002 C5 6 months ago. The car already came with a cam, headers, exhaust, and a CAI.
I want to buy valve springs and have them replaced to be on the safe side. Not sure if I should get .500" max lift springs or .600".
Now my question is how can I find out what kind of cam I have? I took it to my tuner and he said it isn't a small cam, nor is it big. He said it's right in the middle.
I've been looking at videos with stage 2 and stage 3 cams. It is hard to tell what sounds more similar to my car but I come to find that a stage 3 cam idle sounds more identical to my car than how a stage 2 idle sounds.
Any guidance will be much appreciated thanks!
Old Mar 17, 2021 | 12:57 AM
USAZR1's Avatar
USAZR1
.500 lift springs aren't going to be adequate, not even close. My guess is you will need some springs that can handle .660 lift, something like BTR's.
Coil bind from inadequate springs will destroy an engine, quickly.
FWIW, the MTI stage three cam in my Z06 is rated at .629/624
Old Mar 17, 2021 | 11:57 AM
robert3elizondo
Thanks for you input! How often do you have to change your springs?
Also should I be buying a valve spring kit with the retainers and all or should I just focus on the valve springs by themselves?
Old Mar 18, 2021 | 12:32 PM
Moved to C5 Tech.
Old Mar 18, 2021 | 02:32 PM
Speedy007's Avatar
Speedy007
These cost me 185.00
LS LS1 LS6 LS3 LS2 Dual Valve Spring Upgrade Kit .550-.610 LIFT LQ 5.3L LY6
LS1 LS2 LS3 DUAL VALVE SPRING KIT .500-.650 LIFT LQ9 LQ4 LY6 5.3 FREE SHIPPING
FOR USE UP TO .650 LIFT FOR RACE APP
FOR CONTINUOUS USE, MAX .600 LIFT
ALPER MOTORSPORTS KIT INCLUDES
  • 16 DUAL SPRINGS .600-650LIFT
  • 16 HEAT TREATED CHROMOLY VALVE SPRING RETAINERS
  • 16 HEAT TREATED CHROMOLY VALVE SEATS
  • 16 MAHLE VITON SEALS
  • REM POLISH VALVE LOCKS
DUAL SPRING SPECIFICATION
  • OD - 1.290''
  • INNER - .680''
  • 140-LBS @ 1.800''
  • 420-LBS @ 1.150''
  • 420-LBS @ 1.150 Open or Over the Nose
  • COIL BIND 1.050
DUAL SPECS
  • 135-145LBS @ INSTALLED HEIGHT
  • 420-450LBS @ VALVE OPEN .650 LIFT
  • COIL BIND IS AT .755 LIFT
  • SPRING LOCATOR IS .030 THINK
  • 650 Max LIft
Old Mar 18, 2021 | 02:51 PM
robert3elizondo
  • OD - 1.290''
  • INNER - .680''
  • 140-LBS @ 1.800''
  • 420-LBS @ 1.150''
  • COIL BIND 1.050
DUAL SPECS
  • 650 Max LIft
Do you have the link to where you purchased those?
*Edit* Found them, they are off of ebay.
$185 Ebay Valve Spring Kit
Are ebay valve train parts safe to buy?
Old Mar 18, 2021 | 04:32 PM
Smoken1's Avatar
Smoken1
I would not put those in my car. Look at BTR's site
Just remember, Cheap, Fast, Reliable Pick 2 you can't have all 3
Old Mar 18, 2021 | 04:41 PM
grinder11's Avatar
grinder11
You're taking a risk I would never take. You're putting critical pieces into an expensive engine, when you are really at someone's mercy whether they're being truthful or not. Here is a perfect case. I remember years ago, when I pulled my Comp 921 dual springs out. I thought about selling them used for $150.00. At the time, they were over $300 new, just for springs!! But mine had been set up wrong from the beginning by AFR. Installed height was set at 1.700", instead of the correct 1.800". Could anyone tell? Probably not, unless they had a valve spring pressure tool, with a scale and dial indicator. They looked brand new. I was SO tempted. But I thought about how I'd feel if I was the guy buying them, maybe 1 would break, and then a set of $150 valve springs would take out a $8,000.00, or more, expensive engine. I couldn't stand the guilt if that happened. So they went in the garbage🗑.......
To Valve Spring Question
