C5 Corvette no start no spark
While tackling the engine wiring we came to find that we had some missing connectors and mechanically headers, spark plugs, even things like the intake manifold were not tighten correctly. ( I am assuming since he did not include the turbo set up he was installing he just placed everything back together quickly) Now we tried starting the car and noticed the starter is doing its job and the battery is above 12.3v but I could not hear the fuel pump and did not see any spark with testing, we came to find that some of those connectors were for the Camshaft sensor as well as the Oil sensor, we took the manifold and installed them and the fuel pump was now working! but unfortunately again there was no spark still.... so now I question if its the Crankshaft sensor??? I do not have any codes for the PCM the BCM or the IPC, I have checked the grounds on the doors since I installed the harness, I did check the grounds underneath the battery and the one underneath the headers near the starter. Now the reason I suspect the CPS is because I never connected that cable because its not with the engine wiring harness that came with the car, I do have some connectors left which I will provide pictures (which I suspect are for the cats or stock headers) but none of them are a 3 pin Dark Blue, Yellow, Green like wiring diagram suggests. The wiring diagram does show that clearly these 3 wires go to the PCM so I am confident that I am missing, the connector or perhaps previous owner cut these wires cause they're hard to reach??? I am hoping someone would elaborate and confirm that the CPS wires indeed are part of the engine wiring harness and where the split point is so I can see if he cut them or where to look as I cannot find pictures of the wiring route itself only through the wiring diagram. Or if the wires are not part of the wiring harness where they lead to then? Any help is appreciated and thank you
thank you for this! I will definitely test that out, I am hoping that either my wiring is incorrect or the sensor is bad. I’ll keep you guys updated today.
OK, if no spark from a coil pack or no injector pulse you’re looking at a bad CKP or wiring or both !!
even with a bad cam sensor the car WILL still start...however a little longer !!
10PCM - P0335 C , P1637 H C , P1638 H C
28TCS - C1232 H C , C1233 H C , C1248 H C , C1295 H C ( I believe the 1232 1233 are my unconnected wheel speed sensors...)
A6 SCM - B2606 ( reclining seat position is not working )
B0 RFA - U1000 H C
Also the radiator fan would turn on when the car is on the key OFF position and would turn off with key position in ON (weird) and the headlights pop up and light up when also switching key ON ( the light switch lever is on OFF though)
Now I think the most interesting are obviously the PCM codes and the U1000 RFA code. After doing some research so far I found the U1000 is a loss of communication with a XXX module correct? It should be accompanied by another Uxxxx code stating the module where signal was lost or interrupted, but it does not. I have read that the U1000 code appears alone when reconnecting a battery, I am open to interpretations.
Now as far as the P0335 goes the CKP Sensor Circuit is likely the culprit and as you told me C5 Diag that it could be the crappy new sensor OR checking the power, low reference ground and signal wire link that you sent me. I did read however when paired with P1637 and P1638 code it could be either that it needs a relearning procedure or perhaps the PCM is bad or different????? I do not know what the PO has done other than the mods he listed to me, but I am worried now that the PCM this car has installed may be possibly different? I hope I am not going paranoid, or looking too hard into this, any other inputs arre very appreciated and again thank you C5 Diag for the help you have provided.
I suggest you back up and trouble shoot volts and grounds to the inj’s and coils. There are actually 2 grounds on the coil primary side, so you need to chase +12v . Then, if you get relay 42 to energize, you should be getting spark and fuel to start. Yes the ckp needs to be fixed, but that may be a problem created attempting to solve another problem.
The mindset you need to keep when electrical troubleshooting is, in the end (99.9% of the time), there is only one problem, fix it and all is good.
