clutch issue
Old Apr 19, 2021 | 06:34 PM
Californiadreaming464's Avatar
Banned Scam/Spammer
Originally Posted by frodo84
I would check the input shaft carefully for runout. If he jacked it into the bearing I hope the shaft isn't bent. Good luck, keep posting!
EDIT: When you put it back together, stab the torque tube alone, then put the trans assembly on after.
ill definitely do this to ensure the bearing doesn't do the same thing
Old Apr 19, 2021 | 07:32 PM
redzg's Avatar
redzg
Originally Posted by Casey Tocher
you can see my findings above, might interest you
There's an understatement! Fascinated by the results. I note your thinking about a bushing instead of a roller bearing -- have to note that all of the 70's and earlier manual chevrolets I've owned had pilot bushings. When I had the clutch done (last year/this year? I've lost track of time) I went with the OE bearing -- but also went with the best known shop in central FL to to the work. So far, so good.
Old May 30, 2021 | 02:07 AM
Banned Scam/Spammer
hello all, i have returned. after over a month of ripping things apart and a rebuilt gearbox and tube, i finally finished the car. went for a test drive today and all seems to be well. i do seem to be getting an ABS and traction control light randomly, not sure if this is from the battery being drained for so long. my dash also keeps saying service car soon, even though i just serviced pretty much every part of the whole car. but other than that its working very nicely, i appreciate your help and thank you guys heaps
