Need help 2000 C5
Old Apr 3, 2021 | 06:18 AM
Memike's Avatar
Memike
2nd Gear
Default Need help 2000 C5
I just replaced my engine wiring harness and now I have no throttle response what do I do
Old Apr 3, 2021 | 08:26 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Welcome aboard Mike!!
Best to post your question in the C5 section. Mod will probably move it.
Good Luck!
Old Apr 3, 2021 | 12:02 PM
Moved to C5 Tech.
Old Apr 3, 2021 | 01:22 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Make sure your TPS Sensor and TAC motor connectors are fully seated !!
Old Apr 3, 2021 | 07:59 PM
Memike's Avatar
Memike
2nd Gear
I've ck all connecters and grounds
Old Apr 4, 2021 | 09:19 AM
helga203's Avatar
helga203
Was harness new or used. Is it oem?
Old Apr 4, 2021 | 09:22 AM
bonesbrakr's Avatar
bonesbrakr
If you have no trouble shooting skills whatsoever then you take it to someone who does.
If you do have some trouble shooting skills then what codes are happening?
By no throttle response do you mean the throttle isnt opening or the car is sluggish?
To Need help 2000 C5
