Lumbar controls
Old Apr 3, 2021 | 02:53 PM
djohn3853's Avatar
djohn3853
St. Jude Donor '21
Default Lumbar controls
So, i'm finding that there might be a problem with the power seats. I don't find the seat very comfortable. I have zero lower back support. When I use either of the lumbar controls, or the bolster control, I hear a motor (or something) running but I don't feel any movement on the seat at all. Since I hear something running, does that rule out a blown fuse?
Dave
Old Apr 3, 2021 | 03:24 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
If you hear a motor running when you engage the button then its not a fuse issue. Do a search and I believe you'll find other posts on this issue. It may be that the bladder is leaking which is fixable if you're handy to DIY or take it an upholsterer to fix.
Old Apr 3, 2021 | 03:50 PM
djohn3853's Avatar
djohn3853
St. Jude Donor '21
Is there a separate bladder for the bolster one?
Old Apr 3, 2021 | 05:08 PM
GroundFlyer's Avatar
GroundFlyer
St. Jude Donor '19
IIRC there is no bladder for the bolsters, just mechanical motion.
Old Apr 3, 2021 | 05:29 PM
Autoeng's Avatar
Autoeng
There are 4 bladders per seat, 2 in the lumbar area and 1 each on the bolsters. There are threads on here where people used blood pressure cuffs to replace the bladders.
IMO, the best one is:
https://www.corvetteforum.com/forums...vil-style.html
Old Apr 3, 2021 | 06:21 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Dave
Here ya go !!!
Old Apr 4, 2021 | 12:58 AM
Moved to C5 Tech.
Old Apr 4, 2021 | 02:11 PM
djohn3853's Avatar
djohn3853
St. Jude Donor '21
Wow. I've seen a few of Lyles videos before. And he sells the parts. Thats why I love this forum. Thanks everyone. Yesterday I only knew about the drivers seat. Today I checked the other seat and nothing works there either.
Dave
Old Apr 4, 2021 | 08:13 PM
Autoeng's Avatar
Autoeng
Dave
In my seats they do work but there is very little movement actually translated through the seat foam to my back. It is really easy to undo the clip at the bottom of the back and unzip it so you can inspect the bladders. You might be surprised that they are filling but they just aren't big enough to make much of a difference.
Old Apr 5, 2021 | 10:25 AM
grinder11's Avatar
grinder11
Dave
Dave, if you watch Lyle's video's, look for the one with a simple pump fix. It's not always the bladders. The pump vanes can 'freeze' up, and a simple cleaning of the vanes may cure the problem. Check it out. I believe the first thing to check is whether or not the pump is pumping air. You simply remove the plastic tubing at the pump outlet, activate the pump, and see if it is blowing any air. Lyle can take it from there.....
To Lumbar controls
