AC tensioner torque spec
Old Apr 4, 2021 | 01:14 AM
hEllberg's Avatar
hEllberg
Default AC Belt tensioner torque spec
Hello, I had taken off my ac tensioner and was suppposed to reinstall, for this I used a torque wrench set to 37ft lbs, which is the right spec that I managed to find, this actually stripped the threads in the bracket.. Did I use the wrong torque spec? What is weird to me is that its the same torque spec on the tensioners when the ac tensioner uses a smaller bolt.
Im just gonna try and put in a longer bolt and see if there is some more threads deeper, and this time I will just tighten on feel
Old Apr 4, 2021 | 01:57 AM
Smoken1's Avatar
Smoken1
37 is correct.. Here is a quick reference guide for you
File Type: pdf
Old Apr 4, 2021 | 10:59 AM
hEllberg's Avatar
hEllberg
Thats the same reference guide I used. Well just bad threads then I guess
Old Apr 8, 2021 | 10:45 AM
grinder11's Avatar
grinder11
I've NEVER torqued the idler wheel bolts, and never stripped them, either. Either your torque wrench is bad, or the previous owner had already partially stripped them. I use a 3/8" drive ratchet, and iirc, a 15mm socket. With a 3/8 drive, I think it would be pretty hard to strip the threads, unless your Andre the Giant! As for repairing, I recommend a helicoil, or a threaded insert of some kind. You may be able to get a longer bolt, and use a nylock lockout threaded onto the longer bolt. In my opinion, the longer bolt/nylock nut is cobbling it up, but it may work......
Old Apr 8, 2021 | 04:41 PM
hEllberg's Avatar
hEllberg
It wasnt for the idler wheel. Its for the whole AC tensioner, this bolt is also smaller than all the others and not 15mm, its 13mm if I remember correctly. I can agree that stripping any of the other threads, I need to be Andre the Giant, but on this one I probably got it torqued til around 30ft/lbs before it stripped, thats still alot lower than it should, so I'm pretty sure the last owner had already stripped it.
Old Apr 8, 2021 | 11:13 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
You got unlucky.
I basically torque those to “snug” with a couple drops of blue loctite.
They aren’t critical, 25lbs vs near-stripped won’t keep them in place any better than loctite and feel for what is tight.
Old Apr 10, 2021 | 03:00 AM
vette4fl's Avatar
vette4fl
Originally Posted by ~Josh
You got unlucky.
To AC tensioner torque spec
