C5 Auto shift points
Old Dec 13, 2002 | 03:35 AM
wlutgen's Avatar
wlutgen
Default C5 Auto shift points
Hi all. I'm doing a driving simulator for work, and am using the C5 vette for test data. I was wondering if there is a formula that I could use to calculate the RPM's at which an automatic C5 will shift at as a function of throttle position (0-100%)? A table would work too, though it would be less convenient.
Thanks in advance for any help or pointers :)
Old Dec 13, 2002 | 01:21 PM
vstella's Avatar
vstella
Default Re: C5 Auto shift points (wlutgen)
Alot will depend on the program. With one rear end ratio vs. another..Hp/Tq..finding that sweet spot to shift at is a matter of programming. As a guide the owners manual will tell you the limits of each gear.
In my case the programming has been modified to optmize the h.p./tq and the rev limiter has been increased to maximize the powedr of the shifts. I also have a Transgo shift kit installed in my transmission which provides clean quick shifts..:D
Old Dec 14, 2002 | 10:15 AM
kp's Avatar
kp
Here is a stock 3.15 A4 shift vs TPS table, hope it helps you out :cheers:
I guess you have to click on it to get full size..
[Modified by kp, 10:16 AM 12/14/2002]
Old Dec 15, 2002 | 06:15 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Re: C5 Auto shift points (kp)
When I clicked on the link, it came up kinda fuzzy but some of the numbers didn't look right. For my 2001, A4, 3.15 axle, full throttle upshifts come at:
1-2: 45
2-3: 85
3-4: 135
Or at least, that's as close as I can read the speedo during the mad rush!
Old Dec 15, 2002 | 08:11 PM
kp's Avatar
kp
Default Re: C5 Auto shift points (Gearhead Jim)
it has to meet both mph and RPM for it to shift, my 1-2 is set at 42 mph but it doesnt shift until the rpm reaches 6350 (where I have it set) which is ~49mph. There is another table that shows the rpm that you adjust as well. Those are stock numbers right from a stock PCM..
Old Dec 15, 2002 | 08:28 PM
gojo's Avatar
gojo
The chart kp put up is for part throttle shifts. The shifts your show are at wot and must have mph and rpm parameters met to occur, as he points out. The chart the poster would like is not possible for the reasons Manny points out. But, those shift points are fairly consistant if you have a steady foot and under similar conditions like a flat road.
Try this link, it probably is okay for your project. http://www.smokemup.com/auto_math/mph_range.php
[Modified by jfpilla, 8:31 PM 12/15/2002]
Old Dec 15, 2002 | 09:45 PM
wlutgen's Avatar
wlutgen
Thanks guys. I'll look these things over tomorrow :)
-- Wade
To C5 Auto shift points
