Oil pump
Old Apr 23, 2021 | 09:27 PM
1997 C5's Avatar
1997 C5
Default Oil pump
I need recommendation on a oil pump. My build will be BTR Stage 2 cam kit on A/T.
Should I go with melling high volume high pressure oil pump ? or standard one?
Old Apr 23, 2021 | 10:51 PM
rjacobs's Avatar
rjacobs
katech high volume.
I wouldnt personally run a high pressure pump.
Old Apr 23, 2021 | 11:10 PM
Smoken1's Avatar
Smoken1
The 10295 pump should be fine
Old Apr 26, 2021 | 11:08 AM
grinder11's Avatar
grinder11
Originally Posted by rjacobs
katech high volume.
The stock pump puts out plenty of pressure, unless you've installed oil squirters. I've run the Hi-Volume Melling pump for many years. A high volume pump will run same pressure as stock. If you are tracking the car, and the motor starts starving for oil, for whatever reason, a HV pump recovers the pressure quicker. It pumps no more volume than stock, with stock bearing clearances. It's a myth that a Hi-Volume pump pumps the pan dry of oil. It can't pump any more volume than stock, unless you've opened up bearing clearances for racing purposes. Then you may need a larger sump capacity. A high pressure pump WILL pump more oil, because with more pressure comes more oil seeping past the same clearances.....
Old Apr 26, 2021 | 11:19 AM
grinder11's Avatar
grinder11
Originally Posted by Tj893198
10-294 is the correct pump. Otherwise you’ll pump air into your oil with the 295.
This is NOT the correct pump-UNLESS you run a priority main aftermarket block, which is NOT the case with the vast majority of LS blocks in existence. The 10296 Melling is the Hi Volume, standard pressure pump. It comes with the standard pressure relief spring installed, but also comes with a stiffer, hi pressure relief valve spring, not installed, but included for those with larger oil sumps.
Old Apr 26, 2021 | 01:53 PM
1997 C5's Avatar
1997 C5
I went with Melling M295HV stock replacement type high volume oil pump.
Thanks guys for all your input.
To Oil pump
