Bolts question
Old Apr 27, 2021 | 03:31 PM
1997 C5's Avatar
1997 C5
Default Bolts question
Are OEM intake manifold bolts, cylinder heads bolts, exhaust manifold bolts TTY( torque to yield on 97 c5?
Old Apr 27, 2021 | 04:00 PM
frodo84's Avatar
frodo84
Uneducated autodidact
Head bolts yes, I say no to the others.
Old Apr 27, 2021 | 04:07 PM
Smoken1's Avatar
Smoken1
I've reused my intake and exhaust bolts with no issues. I would get ARP head bolts or studs as they are reusable
Old Apr 27, 2021 | 04:41 PM
helga203's Avatar
helga203
Old Apr 28, 2021 | 02:59 PM
1997 C5's Avatar
1997 C5
Thank you everyone.
Old Apr 28, 2021 | 04:24 PM
rjacobs's Avatar
rjacobs
intake manifold bolts can be re-used. exhaust manifold bolts as well(although you MAY break a bunch while removing them, be careful during this step).
Head bolts are most definitely one time use. The regular ARP are a great upgrade. Studs are not needed for just a cam car like you are doing.
If you go back with GM head bolts you will need to buy the tool for tightening by degrees and not torque. First pass is torque then the second pass is degrees. They arent expensive, but IMO better money spent moving to ARP's.
And dont forget when you have the heads off to go back in with a GM MLS gasket and not an aftermarket single layer.
To Bolts question
