Help...Normal A-4 Tranny Temps?
Old Dec 14, 2002 | 11:17 AM
twincam47's Avatar
twincam47
Default Help...Normal A-4 Tranny Temps?
Need info on normal driving
a-4 tranny temps......
Old Dec 14, 2002 | 11:49 AM
Mitch C's Avatar
Mitch C
Default Re: Help...Normal A-4 Tranny Temps? (twincam47)
Before I installed my tranny cooler my average tranny temps were 195 to 201. After installing my tranny cooler(B&M 28,000 cooler) temps have never exceeded 180 so far.
98 A4
Donaldson Blackwing
Cartek Stage 2 Heads
Cartek M cam
LS6 Inatke
TPIS Headers
Underdrive Pulley
Comp push Rods
ST3500
3.73 Gears
B&M Trans Cooler
172 T.stat
Old Dec 14, 2002 | 12:00 PM
twincam47's Avatar
twincam47
Default Re: Help...Normal A-4 Tranny Temps? (Mitch C)
thanks............
any others? :confused:
Old Dec 14, 2002 | 12:38 PM
Face's Avatar
Face
Mine are also in the 190-200 range.
Old Dec 14, 2002 | 04:35 PM
bgood's Avatar
bgood
Cruise-In IV Veteran
St. Jude Contributor
In the summer here in Atlanta my tranny temp would stay in the 205-230 range. After installing Z06 front screens and drilling 3/8" holes in the plastic around the fog lights (with a homemade template) my tranny temps dropped an average of 15 degrees.
Note: drilling out the plastic by the fog lights is a lot easier than installing the WCC cold air screens.
Old Dec 14, 2002 | 05:01 PM
Purerock105's Avatar
Purerock105
Almost exact to mine. 98 A4 with SY3500 and the B&M. :cheers:
Old Dec 14, 2002 | 09:21 PM
hogurt's Avatar
hogurt
Default Re: Help...Normal A-4 Tranny Temps? (Purerock105)
Seems like my temps were running just under 200. Unfortunately, the car is up for the winter. . .so I can't check it right now.
Old Dec 14, 2002 | 10:43 PM
Steve'01's Avatar
Steve'01
Default Re: Help...Normal A-4 Tranny Temps? (hogurt)
Mine runs 180 to 190 after trans cooler. Prior to cooler I hit 230 one day on the road to Las Vegas hitting some high speeds. A cooler is a wise investment on any Auto. :cheers:
Old Dec 15, 2002 | 02:19 AM
twincam47's Avatar
twincam47
Default Re: Help...Normal A-4 Tranny Temps? (Steve'01)
Thanks you guys for all the input.........
Looks like a cooler is in order........
Lord knows I've spent enough on other
mods.....tranny longevity is a must.....
:thumbs: :flag
Old Dec 15, 2002 | 02:47 AM
NV MY C5's Avatar
NV MY C5
Senior Member
Cruise-In V Veteran
On the street, mine is about 180-190. Took it out on the track it got up to 254 :eek: . May also want to consider a deeper pan...
Old Dec 15, 2002 | 03:12 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Help...Normal A-4 Tranny Temps? (bgood)
I was debating about the screens, but my daughter said she thought the car came this way.
My temps have ranged from 185 to 213 depending on the outside temp!
[Modified by wallstAL, 12:15 AM 12/15/2002]
Old Dec 15, 2002 | 05:25 PM
nmbis2k's Avatar
nmbis2k
Steve - which trans cooler do use install, at what location?
And, which engine cooler and where?
My C5 runs hot only in traffic, and I might but a PCM programmer just to set the cooling fans "on @215 degrees".
Thanks. Bob Scott "nmbis2k"
To Help...Normal A-4 Tranny Temps?
