Need Harmonic Balancer? 98 C5
Old May 14, 2021 | 08:57 AM
Chad C's Avatar
Chad C
Cruising
Default Need Harmonic Balancer? 98 C5
My harmonic balancer seems to wopple a bit.. Any thoughts?
Old May 14, 2021 | 09:00 AM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
https://www.youtube.com/watch?v=P-4mBn3JF_g
Replace it.
Old May 14, 2021 | 09:18 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Your balancer is wobbling, and from the angle of the camera, it also appears that the belt isn't tracking squarely on the pulley. My suggestion is to replace it ASAP, before you need to replace the steering rack, too........
Old May 14, 2021 | 05:06 PM
knewblewkorvette's Avatar
knewblewkorvette
Originally Posted by XFIRED
Replace it.
Old May 15, 2021 | 03:02 PM
hawk4077's Avatar
hawk4077
This is not something to put off it dose not get better or go away.
Old May 18, 2021 | 05:31 AM
Chad C's Avatar
Chad C
Cruising
So taking it to a local dealership, will a new oem replacement be OK? Did they improve them over time?
will probably have them replace the 2 tensioner and pulleys, and oil seal while they do the balancer also.
Old May 18, 2021 | 07:51 AM
FIVE12 GARAGE's Avatar
0FIVE12 GARAGE
Former Vendor
Like others have said, this should be replaced. Many folks opt for an aftermarket damper from either ATI or Fluidampr in lieu of a factory GM replacement.
Here's a link to a few options and the ARP bolt kit: https://five12garage.com/collections...pe=Bolt%20Kits
Let me know if you have any questions. Always happy to help!
Scott
MODERN CORVETTE PERFORMANCE PARTS & ACCESSORIES!
Website:
https://www.five12garage.com
Youtube:https://www.youtube.com/team512
Instagram:https://www.instagram.com/five12_grage
Old May 19, 2021 | 11:09 AM
Zmeister's Avatar
Zmeister
For sure replace the balancer as soon as you can.
Mine started to wobble a little bit just like yours. Continued to drive the car to work while I was ordering the parts and studying up on how to replace it.
One morning the balancer spun off. Luckily it spun off the back and just messed up the timing cover a bit, and, luckily I only got about 2 houses down the street before it came off. I would hate to imagine it would have been if I had gotten to the interstate!!!
You immediately know when it comes off because it make a horrible racket when it does!!
Good luck!!!
Old May 19, 2021 | 03:36 PM
grinder11's Avatar
grinder11
DON'T go to the "Stealer"!! I've had GREAT luck with ASP underdrive balancers. More economical than many, and durability is very good (no wobbles). If you go to the "Stealer", they'll find other "problem areas", and you'll be lucky to leave for less than $1,500.00, even with no other problems. It's really not that difficult to fix yourself, if you have any mechanical ability/experience. It is time consuming, however. Best of luck to you.
To Need Harmonic Balancer? 98 C5
