Window won’t go up!
Old May 25, 2021 | 03:21 PM
Ryukin's Avatar
Ryukin
Default Window won’t go up!
so for a while now the window would get stuck halfway and I would have to mess with it to get it down. It sounded like something was grinding the window so I didn’t think it was anything too serious. But today it went down and will now come back up. See the attached video. It sounds like it is going down but to come up it makes a noise for a while then just clicks
https://youtube.com/shorts/UDmv2vppWOk?feature=share
Old May 25, 2021 | 03:25 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I don't see any video. However, it sounds like it could be your window regulator. That's a known failure point on the cars. You can try gently banging on the door to see if that helps. More than likely you'll need to replace the regulator though.
Old May 25, 2021 | 03:34 PM
Ryukin's Avatar
Ryukin
Even if it’s temporary I need a fix to get it up
Old May 25, 2021 | 04:32 PM
Ryukin's Avatar
Ryukin
U
Update. I don’t know what this is but it’s not connected to anything
Old May 25, 2021 | 05:03 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
That is your window regulator that has failed.
You can usually manually pull up on the window and then use something inside the door to prop it up or tape it to the car to hold it as a temporary won't-get-rain-inside fix.
Old May 25, 2021 | 05:09 PM
Ryukin's Avatar
Ryukin
the right side of the regulator won’t go up I ended up taking of off the rails. Do you have any recommendation on what to use to hold it up? The windows pretty heavy
Old May 25, 2021 | 05:16 PM
Stingroo's Avatar
Stingroo
Paint sticks from Home Depot work great for this. I've wedged them between door panels and windows in the past - and they're free.
Since you don't have an upper frame on a C5, you might have to get creative and wedge them between the bottom of the glass and the bottom of the door.
Old May 25, 2021 | 06:56 PM
15W40's Avatar
15W40
Regulaaatoooors, MOUNT UP!
(Not sure if there's a cross section of people who drive corvettes and listen to warren g...)
Yes, buy a new regulator and make sure there's nothing else in there interfering with the window that caused this one to fail.
Dorman regulators are cheap but I've had good luck with them. Supposedly they make improvements to whatever part of the OEM one fails. MSRP on a genuine part is $325. You can get the dorman for $55
Old May 25, 2021 | 06:57 PM
Stingroo's Avatar
Stingroo
This is the kind of repair that's best performed on a clear black night under a clear white moon....
Old May 26, 2021 | 09:47 AM
WDEagle's Avatar
WDEagle
I just replaced my (passenger side) regulator & motor last week.
Here's what/where I bought it. Here's what/where I bought it.
Make certain to get the adapter plug if you buy this one.
Very easy to install.
Edit: Damn thing has gone up $40 since I bought it.
Old May 26, 2021 | 11:01 AM
Ryukin's Avatar
Ryukin
I ended up getting this one https://www.carparts.com/details/Che...EPC462954.html
Old May 26, 2021 | 11:44 AM
Ryukin's Avatar
Ryukin
i actually do know the song. Probably because I’m not a typical corvette owner lol
Old May 26, 2021 | 12:01 PM
Moved to C5 Tech.
Old May 26, 2021 | 03:29 PM
heggsc5's Avatar
heggsc5
I just replaced my driver window regulator this weekend as well. Used an "Ultra Power" brand from Rockauto for $40 since it was the "favorited" option there. No adapters or modification needed, swapped right over and works like a charm. Picked up a passenger side to reaplce both, but I think I'll hold until it's actually needed so I don't break any more plastic door pins. 20 yr old plastic is risky business, even when you're careful and have the proper tools lol.
Old May 28, 2021 | 09:41 PM
WDEagle's Avatar
WDEagle
Nice price. I'll keep that in mind in case my drivers side goes bad. Keep up posted on how it is working out for you.
To Window won’t go up!
