PO 410 Code - help needed
Old Dec 15, 2002 | 09:05 PM
65midyrowner's Avatar
65midyrowner
Cruise-In VIII Veteran
Default PO 410 Code - help needed
My girlfriend owns a '00 cpe. The check engine light came on, so I read the code which reveled PO 410. Her car is out of warranty. Any tips on how I can eliminate this problem? Send tips to GTalley99_99@juno.com
Old Dec 15, 2002 | 10:32 PM
TLY-BAMA's Avatar
TLY-BAMA
Default Re: PO 410 Code - help needed (65midyrowner)
Gene you've got mail. :flag
Old Dec 15, 2002 | 10:34 PM
Jim 47's Avatar
Jim 47
P0410 is the secondary AIR Injection System (or System B).
Old Dec 19, 2002 | 01:13 PM
Orbit's Avatar
Orbit
I had the same code about 3 months ago. My positive battery terminal had cracked and acid had run down on a vacuum line eating a hole in it. Mine was under warranty so GM took care of repacing the air line, battery and cleaning all the acid that had accumulated in the area. I now look at the battery area everytime I wash the car to ensure no acid is leaking again and that I don't see any signs of corrosion. Good luck. BTW, the cracked battery terminal is common for the Corvette. :D
To PO 410 Code - help needed
