upper radiator support bolt size
Old May 30, 2021 | 11:40 AM
Justin Raney's Avatar
Justin Raney
Default upper radiator support bolt size
My car was missing the upper radiator support. However i purchased one from gm parts direct which should arrive tuesday. I see the frame has 2 bolt holes on each side or nut inserts. What size bolt does this use mainly the thread pitch?
Old May 30, 2021 | 01:12 PM
Smoken1's Avatar
Smoken1
If your talking about the plastic cover then they are M6x1x25
Old Jun 2, 2021 | 01:09 PM
grinder11's Avatar
grinder11
YES!!!! FINALLY someone lists a bolt size as it should be, NOT the hex size!!!
Old Jun 2, 2021 | 01:59 PM
Smoken1's Avatar
Smoken1
It helps when you have a parts catalog
To upper radiator support bolt size
