transmission not centering after rebuild
Old Jun 3, 2021 | 03:01 AM
Californiadreaming464's Avatar
Banned Scam/Spammer
Default transmission not centering after rebuild
hello i own a 1997 non z06 C5 and I've just taken the whole torque tube and all the rest that goes with it for an unrelated issue. in the meantime i had my transmission rebuilt as first and second synchro's where shot. the car is now running good and the gearbox is good, but same as before the transmission will not center at all back to the 3rd 4th gate. its much smoother but there is no spring in it at all. the gearbox shop has offered to rip the box out and fix it but i cant seem to find any conclusive evidence on if its there are even any centering springs in the gearbox or if the centering spring is meant to come from elsewhere, any information on this subject would be appreciated as i don't want to have it ripped apart again unless it has to be. cheers.
Old Jun 3, 2021 | 11:14 AM
helga203's Avatar
helga203
Yes there is a spring the only way to fix this is the trans must out.
Spring is in the back where the 1 2 synchors are. but try to adinle the sifter box first but i dont thing thats going to work.
Old Jun 3, 2021 | 07:45 PM
johnson-rod's Avatar
johnson-rod
You can try pulling the big bolt with the spring inside that sets the shifter centering.
It's on the passenger side of the transmission about 3/4 way up to the top. You can't see it (or photograph it) so you have to do it by feel. It's big - 13/16" or 7/8" size.
It's the bolt head that you put washers under to make the shifter lose it's self centering. I can't remember the name of the "mod" (getting old).
Pull the bolt and see if the spring is shot.
You don't need pull the trans to do this. Just lift the car up enough to crawl under the passenger side.
Old Jun 4, 2021 | 08:05 PM
69's Avatar
69
Cruise-In VI Veteran
Originally Posted by Casey Tocher
, but same as before the transmission will not center at all back to the 3rd 4th gate..
I suspect that you may have an issue in the following areas which will require the trans to be disassembled for further evaluation;
1) Missing or broken shift shaft neutral return cam pin.
2) Broken neutral return cam spring.
3) Worn neutral return cam to shift shaft neutral return cam pin, (worn return cam pin groove).
If you find you do have issues with these parts upon inspection, you will have to source them from FleaBay or a corvette scraper as GM does not stock/sell them anymore...Not sure if can be purchased thru TREMEC though...
Double click on Pic to enlarge
Post up your findings when you find the root cause of the problem.
Cheers,
Goose
Old Jun 5, 2021 | 10:29 PM
Banned Scam/Spammer
i might try this to before sending it in
Old Jun 5, 2021 | 10:30 PM
Banned Scam/Spammer
thankyou very much, this reply was really detailed i couldn't find any exploded images like this anywhere. i might forward this to the gearbox guys, might help them
Old Jun 5, 2021 | 10:32 PM
Banned Scam/Spammer
So seems like its definitely something that will require the box to be pulled. witch is fine. at least i know for sure there's nothing i can do. it will all be free and under warranty. i appreciate you guys sharing your knowledge with me. cheers
Old Jun 6, 2021 | 11:45 AM
Ferg03 Z06's Avatar
Ferg03 Z06
Anti-venom mod
Old Jun 6, 2021 | 02:03 PM
helga203's Avatar
helga203
I'm pretty sure that has nothing to do with centering. I think its pulling back and forth into gears.
Will at least it didn't work for.
mine still would not center except with a little bump.
Old Jun 9, 2021 | 02:29 AM
Banned Scam/Spammer
Originally Posted by Ferg03 Z06
Anti-venom mod
that seems odd, is there any purpose for this mod. i cant see why that would be desireable.
Old Jun 9, 2021 | 09:43 AM
MultiVAC's Avatar
MultiVAC
Hey I literally did this exact thing in February. Did the whole thing twice. The first time around the pin (#3) that connects to that spring in 69's diagram had fallen out.
I found it on the ground the day after I had it all together the first time.
Doing it the second time around it made a ton more sense. I also had to fix my leaky seal job. During the second disassembly I found that the 5-6 cluster was chewed into the mainshaft spines. (Also its supposed to be press fit on its taper, mine was loose.)
So a new 5-6 cluster and HD mainshaft later it's all together again.
It will decrease the notchy-ness at the end of shifter travel. What it does it decrease the amount of travel that the shift detent ball must be depressed by spacing it outward by the thickness of the washer(s) that you use.
To transmission not centering after rebuild
