Rear CD changer - repair and/or replace?
Old Jun 3, 2021 | 03:31 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Default Rear CD changer - repair and/or replace?
The rear CD changer in my 98 finally took a dirt nap.
It has 12 of my favorite discs stuck inside right now.
I removed the unit from the car, and will try to free them.
My preference would be to REPLACE the unit with something that uses solid state digital storage for the music, but can connect on the existing harness in the rear.
Does this exist?
I found the "Discount Car Stereo" website that sells harnesses to add aux inputs, or bluetooth.. but you must have a working 12 disk changer to use these!
I found some old threads.. but nothing too cool.
Also, has anyone repaired/refurbed one of these units?
Thanks,
Fred
Old Jun 3, 2021 | 03:51 PM
rrwirsi's Avatar
rrwirsi
Why do you think the Changer is toast? If the CD's will not eject, maybe it is a stuck CD. Did you try 'lightly' tapping the outside of the unit before removing?
Old Jun 3, 2021 | 05:26 PM
SDVette's Avatar
SDVette
Fair point.. Once I figure out how to get the stuck magazine out, I will know more.
I'd still like to replace the thing.. It is 23 years old, and the CD-format is dying.
Old Jun 3, 2021 | 10:14 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
Discount stereo has different options, some you keep the player and some you remove the player, I know for sure for an iPod, remember those. That's what I have now but, want to upgrade to the bluetooth version in the future, I think they're back ordered the last time I checked. My Ipod has like 5000 songs on it and I keep it in the ash tray, sure better than cd's. Might be worth another look.
Old Jun 7, 2021 | 01:21 PM
SDVette's Avatar
SDVette
Just to update.. It was a challenge, but I was able to extract my discs from the unit.
It took a combination of banging on it, re-connecting the power... more banging... then eventually, just muscling out the last 1-2 discs and caddies.
That thing is a mechanical work-of-art! Lots going on in that thing to move those discs around. Scary, in fact!
I put it back together, and it seems to work OK.
Still looking for a replacement that plugs into the rear and provides Bluetooth input without needed the CD changer to be present.
Old Jun 7, 2021 | 01:49 PM
jcgunn's Avatar
jcgunn
You can try something like this. Don't know if they make a bluetooth one.
https://www.discountcarstereo.com/pxdp-c5.html
Old Jun 7, 2021 | 05:39 PM
grinder11's Avatar
grinder11
Maybe check Crutchfield. Havent bought anything from them in years, but they used to be top notch, with a lot of products.
Old Jun 8, 2021 | 01:23 PM
SDVette's Avatar
SDVette
I emailed that guy.. He doesn't have a bluetooth option.
Old Jun 8, 2021 | 03:19 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
You can buy a $20 Bluetooth adapter that plugs into the cigarette lighter that allows you to play internet music from your phone or music stored on your phone. They work pretty good and no wiring needs to be added. Just need to connect the adapter to the radio via an unused FM channel and the phone to the adapter via the Bluetooth. Do it once and phone will automatically connect to the Bluetooth adapter.
Old Jun 8, 2021 | 03:36 PM
15W40's Avatar
15W40
So I always thought this was a cheesy, cheap way to go until I tried it. Bought a $25 bluetooth cigarette lighter adapter and it works perfectly, including controlling it from the outlet. When you get a BT kit for your factory radio, you cant use the buttons to skip songs or anything.
Old Jun 8, 2021 | 05:48 PM
SDVette's Avatar
SDVette
Thanks for the input guys.. I have always thought those FM modulator devices they were cheesy too... but it's easy to try, and little to loose.
Fred
To Rear CD changer - repair and/or replace?
