Budget radiator upgrade recommendations
Old Jun 18, 2021 | 05:54 PM
jrp1588's Avatar
jrp1588
Originally Posted by heggsc5
And another dumb question, you don't have a front lip that blocks airflow to the air dam, do you? lol
Welp, if you're really oppose to spending $600 (which I don't blame you), you can always throw in a Trackspec center vent for a couple hundred bucks (or find any cheaper vent that will work). That'll help pull air out.
I honestly don't see why a stock radiator wouldn't do the job if the system is in good health otherwise.
I'm running out of cheaper ideas here.
Actually it DOES have a small lip now that you mention it. I suppose I could try removing it and see how it does. I actually quite like it though. I also already have the Trackspec hood vents installed.
Old Jun 18, 2021 | 06:01 PM
Smoken1's Avatar
Smoken1
I would try removing that lip and see what happens, at least that won't cost you anything
Old Jun 18, 2021 | 06:02 PM
heggsc5's Avatar
heggsc5
Definitely remove that lip....wish we would have known that 21 posts ago...LOL. They look good, but they do indeed block the only airflow your radiator gets. I had one the blocked the entire air dam, but had the fans programmed to come on before 200, and never had an issue in 100 degree weather. I'd 100% remove that front lip and give it a run. A lot of people easily experience a 10-15 degree bump when adding a front lip. If anything, you ca just remove it for Summer and put it back on for the rest of the year. That's free
Old Jun 18, 2021 | 06:17 PM
jrp1588's Avatar
jrp1588
yeah, it hadn't really occurred to me. It's a very small lip, probably doesn't extend more than an inch below the bumper. I suppose I could see it disrupting the airflow though. As you said, it's free, and easy enough to try.
Old Jun 18, 2021 | 06:42 PM
rjacobs's Avatar
rjacobs
big mouth air dam... seems to be more popular on the C4's though, but they have a c5 version.
Old Jul 3, 2021 | 09:42 PM
jrp1588's Avatar
jrp1588
Well, you all were right. I removed the little lip, and temps were immediately and noticeably MUCH better. I was cruising around today in mid 80's weather, and it stayed between 185-190 at highway speeds. Similar temps all week commuting on the side streets in 90's weather.
