Code P0480
Old Jun 18, 2021 | 11:38 AM
C5.dro's Avatar
C5.dro
Default Code P0480
On my way to work I got this code P0480 and I looked it up and it’s about cooling fan or wtv which would explain why I saw my temp gauge raise up to 230-240. Will check once I get out of work but what should I look for? Any relays if so what numbers would they be? Connections? Fans? Etc. thanks!
Old Jun 18, 2021 | 11:42 AM
helga203's Avatar
helga203
https://www.corvetteforum.com/forums...an-relays.html
Old Jun 18, 2021 | 11:57 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Could be the Cooling Fan 1 relay (#45), wiring, or even a bad PCM that will set the P0480.
To Code P0480
