Do These Dyno Numbers Look Right?
Old Jun 23, 2021 | 08:04 PM
StimpyV2's Avatar
StimpyV2
Cruising
Default Do These Dyno Numbers Look Right?
I recently purchased a 99 C5 that has a 98 ls1 in it.
The car made 364 hp on a DynoDynamics with the following.
CAI
Stock TB
Stock Intake Manifold
28lb Injectors
Stock 806 Heads
Tick Dual Springs & Push Rods
Tick Stage 3 cam .630/.610 111+3
Long Tube headers (no cats)
M6 Stock Gears
I added:
Mild ported 243 heads
FAST 92
LS2 TB
36lb Injectors
I got the car tuned at a different shop and made 422hp/364tq on a DynoJet
The tuner said his dyno reads a little low but couldn’t give me a number.
Is something wrong here? Do I need to do a compression/leak down test. These numbers seem low especially for a dynojet.
Thank you for your help.
Old Jun 23, 2021 | 08:36 PM
mmartinez's Avatar
mmartinez
The second set of hp numbers seems reasonable for the mods you listed.
Old Jun 23, 2021 | 08:50 PM
Navy Blue 210's Avatar
Navy Blue 210
Looks good to me, what is your comp. ratio?
How does it drive/feel?
Old Jun 24, 2021 | 04:30 AM
dskinsler83's Avatar
dskinsler83
I mean what were you expecting? That is pretty reasonable for basically a LS6 with FAST, cam, and other additional supporting mods.
Old Jun 24, 2021 | 08:20 AM
oharal's Avatar
oharal
I'm actually borderline surprised by that much power. Good results.
Old Jun 24, 2021 | 11:09 AM
helga203's Avatar
helga203
CAI
Stock TB
28lb Injectors
Stock 806 Heads
M6 Stock Gears
I added:
FAST 92
LS2 TB
36lb Injectors
So u went from 364 to 422 just changing to the new modes??
Old Jun 24, 2021 | 11:00 PM
grinder11's Avatar
grinder11
Dynos are good for one thing, and one thing only-To extract maximum power out of an engine. You can't race dyno's against each other, and WAY too many people compare their power figures that were recorded on dyno "A", against figures attained on dyno "B". You should get a top notch tune from a top notch tuner, on that one specific dyno. Then make the mods you want, then take your car back to the same shop/dyno. Doing what you're doing will do nothing but have you running in circles, throwing cash out the window. If you visit enough dyno's, you may just hit 500whp with no further mods!!! Just sayin', not trying to be a smar-tass!!
Old Jun 25, 2021 | 01:24 PM
helga203's Avatar
helga203
yes u r. but ur right. cant get hung up on the numbers. im sure each dyno has a plus and minus to a certain extent. jmo
Old Jun 25, 2021 | 10:02 PM
StingrayRebel's Avatar
StingrayRebel
the graph looks good, don't worry so much about the number but how it performs... get out and race it and see what it does
Old Jun 25, 2021 | 10:11 PM
310's Avatar
310
My LS6 with a Torquer V2 (.595/.598 232/234 112) and stock heads made 425rwhp and 397rwtq. Had long tubes and Vararam with a 25% under drive.
Old Jun 26, 2021 | 03:56 AM
Joevette99's Avatar
Joevette99
My H/C/H work done 12 years ago had dyno numbers like yours. If you want more kick, change rear gears. 3.73 or 3.90 were my choices.
Old Jun 26, 2021 | 07:13 AM
Mikes-Z06's Avatar
Mikes-Z06
Adding the gear REALLY wakes up the H/C combos - Dyno graph looks good - smooth
Old Jun 30, 2021 | 02:25 PM
cv67's Avatar
cv67
St. Jude Donor '05
W/Grinder..most important thing is the gain before/after and where the power is at.
Youll read about many who are learning and start to believe that something is wrong with their car cause their numbers were lower than some guys on the internet. Or thier tuners no good....dyno sheets and flow numbers can be fluffed and misconstued just run the car.
365 tothe ground will get you in plenty of trouble. Can always gear the car to add some more fun factor.
To Do These Dyno Numbers Look Right?
