DTC questions
Old Jun 28, 2021 | 06:08 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Default DTC questions
A few weeks ago, I fired up my C-5, after it had been sitting for about a week, I immediately got 2 DTC codes, the "10 PCM" P1416, and the "28 TCS" C1214. I looked in the shop manual, and they were related to a momentary low voltage situation. IIRC, the P1416 is also tied to the air injection into the exhaust manifold system. Since the low voltage thing was in play, and the battery was 5 years old, I replaced it, and the car was OK for a while.
Today, again after the car sitting for a few days, I went out for "just a ride". I get in, turn the key, the engine fires right up, and a moment later, I get the ABS and traction control icons on the dash lit up, as well as the "DIC messages" stating "Service ABS" and "Service Traction Control". I went for a ride, anyway, and when I got home, I pulled the codes. I again got the P1416, and the C1214, but this time I also got a "60 IPC" B0516. When displaying the codes, the P1416 showed as current code, and the other 2 showed as hysterical codes.
The "low current" codes have me a little confused, as a new battery and a functioning charging system shouldn't be showing voltage drops. And for the B0516, the shop manual says it's due to the vehicle's speed sensor showing less than some incredibly low vehicle speed. Yeah, it should, as the car was stationary!!
Anybody have any thoughts as to why these codes are reoccurring?
Old Jun 28, 2021 | 06:33 PM
Smoken1's Avatar
Smoken1
Have you ever replaced or cleaned the contacts in your ignition switch?
Old Jun 28, 2021 | 06:49 PM
leadfoot4's Avatar
leadfoot4
That's one thing I haven't. Maybe it should be put on the list of "things to do". I'll have to dig up the thread on that.
Old Jun 28, 2021 | 07:00 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
When you start seeing DTC’s from different modules the first thing you should look at as was mentioned is your ignition switch…you can do voltage drop testing between battery positive and the fuse that feeds that module to see if you have excessive voltage drop across the ignition switch…shouldn’t be more than .1 to .2 volts !!
Old Jun 28, 2021 | 07:50 PM
Smoken1's Avatar
Smoken1
https://www.corvetteforum.com/forums...ch-repair.html
Old Jun 29, 2021 | 08:16 AM
leadfoot4's Avatar
leadfoot4
Thanks!!
Old Jul 3, 2021 | 08:27 AM
leadfoot4's Avatar
leadfoot4
Since we all hate the "advice threads" that die without any explanations of resolving the problem, I'm just checking in with an update......
Given that the ignition switch contacts seem to be a common issue, over time, and since we also seem to be seeing where certain electrical components are being discontinued, I looked into acquiring a new ignition switch. Rock Auto Parts had them in stock, so I ordered one. Given that there's a fair amount of disassembly of the console and lower dashboard, in order to get at the switch, I figured I'd simply install a new switch and be done with it. At my convenience, I can then inspect/clean the contacts of the original switch and keep it for "backup".
With respect to the active handling/ABS codes, I happened to be talking with a friend of mine, whose son works part time at a local indie repair shop, and was relating my issues. He called his son, who said that within the next couple of days, he could borrow the shop's "professional" scanner, and hook it up to the car. This unit apparently has the ability to scan ABS issues, which many scanners dont', so we can get a complete picture of what may be causing the codes to be set. That way, I'm not simply throwing parts at the car, hoping to find the problem, while wasting time and money.
Old Jul 7, 2021 | 07:47 AM
leadfoot4's Avatar
leadfoot4
The holiday weekend caused a few delays, but we hooked up the "professional" scanner, a Snap-On unit, last evening. It zeroed in on the EBCM, right away. I removed the module, a short time later and boxed it up. It will be dropped off at the local FedEx depot in a couple of hours from now, and hopefully, in about a week and a half, I'll be back in business.....
Old Jul 7, 2021 | 10:25 AM
C5 Diag's Avatar
C5 Diag
What did you “zero in” on with the EBCM ??…did you at least do the “Automated Test” with the scan tool to make sure the pump motor is working ??…this can either be the EBCM or the BPMV or both being bad !!
Old Jul 7, 2021 | 12:05 PM
leadfoot4's Avatar
leadfoot4
We did the pump test.....
To DTC questions
