Front running/indicator housing problem.
Old Jul 2, 2021 | 10:45 AM
EuroGuy's Avatar
EuroGuy
Cruising
Default Front running/indicator housing problem.
Is it normal that the front running light & blinker work when they feel like it??
I have put in numerous new bulbs, but even then it doesn't work (Drivers side left turn)
It wasn't working when the dry weather started ( coincidence?) then after a car wash it worked?!!!!
The housing does look like it has overheated but isn't cracked & the wires are all intact.
So do l buy a new housing, & if so, where do l get one because l can't find one on Amazon?
Thanks in advance
Basic C5 guy.
Old Jul 2, 2021 | 10:57 AM
v6turbo87's Avatar
v6turbo87
Are the sockets burnt? That is a common issue from the bulbs overheating in the housings. Mine sockets were burnt and the running light would often flicker or go out. Replaced both sockets and what to LED replacement bulbs and problem has been solved.
Old Jul 2, 2021 | 11:06 AM
EuroGuy's Avatar
EuroGuy
Cruising
Any part #'s or where l can get them, Amazon assistant says they don't sell anything like it??
Old Jul 2, 2021 | 11:21 AM
v6turbo87's Avatar
v6turbo87
Dorman Help! 85882 Socket Can get them just about anywhere.
Old Jul 2, 2021 | 12:02 PM
EuroGuy's Avatar
EuroGuy
Cruising
Thank you VERY much for your help, & l have ordered one from Amazon for $13.50 (ish)
THREAD CLOSED.
Old Jul 2, 2021 | 12:17 PM
Moved to C5 Tech.
To Front running/indicator housing problem.
