Engine stalled when doing burnouts/drifts (automatic)
Old Jul 4, 2021 | 12:19 AM
hEllberg's Avatar
hEllberg
Default Engine stalled when doing burnouts/drifts (automatic)
Hey guys!
Was at a car meet and had some fun with my C5, when I spun out doing a drift the car suddenly stalled and I got all types of TCS messages. Couldnt start the car straight away, removed the codes fast and car started up again all good. Was this the torque management hitting me so I don’t break anything?
Old Jul 4, 2021 | 05:22 PM
VetteDay's Avatar
VetteDay
Cruising
Originally Posted by hEllberg
Hey guys!
what were the codes?
Old Jul 4, 2021 | 05:47 PM
hEllberg's Avatar
hEllberg
I reset all codes fast so I could get out of the way for the others, but I did get ABS and traction control light. I am not even sure if it was the codes preventing me to start the car or whatever, but I was able to start it atleast straight after I cleared everything
Old Jul 4, 2021 | 06:15 PM
VetteDay's Avatar
VetteDay
Cruising
without the specific codes, its impossible to help.
Old Jul 4, 2021 | 09:11 PM
lionelhutz's Avatar
lionelhutz
There isn't a "kill the car because you're abusing it code" so without the codes it'd be hard to guess what happened.
Old Jul 7, 2021 | 12:21 PM
hEllberg's Avatar
hEllberg
I am just dumb, I probably rolled backwards a bit with the car in gear, causing the engine to stall, then when I was about to start it the first time I still had it in drive.
Old Jul 7, 2021 | 01:31 PM
3sACROWD's Avatar
3sACROWD
Rolling backwards probably happened and is what stalled the engine. Likely what happened is the engine stopped in a non-normal position so the crank sensor and such was out of sorts. IIRC the engine stops in one of 3 positions and yours likely wasn't in one of them and had to get reoriented. If the engine attempted to turn over when you tried to start it, you were not in drive.
Old Jul 7, 2021 | 06:28 PM
lionelhutz's Avatar
lionelhutz
You let off the gas and it stalled? It shouldn't stall if you're still on the gas even if you spin around and go backwards with the wheels spinning.
Old Jul 8, 2021 | 06:39 AM
hEllberg's Avatar
hEllberg
I most definitely let go off the gas, beginner mistake.. C5 is my first automatic
To Engine stalled when doing burnouts/drifts (automatic)
