Power and engine temp?
Old Jul 6, 2021 | 09:07 AM
royal flush's Avatar
royal flush
Default Power and engine temp?
At what engine TEMP does a STOCK C5 Z06 have the most power ? im guessing around 195 deg.
Old Jul 6, 2021 | 09:41 AM
popshumphrey's Avatar
popshumphrey
St. Jude Donor '16
I don't have a z06 but it seems on the forum that most cars run between 190 and 220. Mine stays around 200. Not sure how the temp affects the power.
Old Dec 4, 2021 | 12:01 AM
douglasjre's Avatar
douglasjre
Default How do I ...
Lowery engine temp to 190?
Old Dec 4, 2021 | 09:51 AM
helga203's Avatar
helga203
Factory setting i believe is somewhere around 225. So maybe GM might know something more than us, but there is a lot of internet truth out there and superbe knowledge. I always go with the internet side.
I might be wrong because i got this info off the internet.
Old Dec 4, 2021 | 10:28 AM
mmartinez's Avatar
mmartinez
Engines are more efficient between 190-220, good target temperature would be around 200. At higher temperatures the engine is more efficient, but then you have to consider the increase of inlet air temperature lowering horsepower .
Old Dec 4, 2021 | 10:30 AM
grinder11's Avatar
grinder11
FWIW, the quickest, fastest 1/4 mile runs I ever made were one after another, without shutting the engine off. The only change from stock at that point was a 160° T-stat. I'm a believer in the engine/trans/diff being hot (nothing overheated), with the coldest IAT (intake air temp) you can get.....
Old Dec 5, 2021 | 11:22 AM
helga203's Avatar
helga203
LS engine ??? I bet if the engine temp was a 1000 * it wouldn't matter as long the IAT is low as it's going to be, it's going to be the fastest its gonna run
Old Dec 6, 2021 | 12:30 PM
grinder11's Avatar
grinder11
Hey, MERRY CHRISTMAS, Helga, and MERRY CHRISTMAS TO EVERYONE!!! Yup, a 2000 LS1. Tuned with bolt-ons, my 2000 A4 ran a best of 12.89@109.97mph. This was thru stock exhaust manifolds, no cats, 3.15 G92 diff. Thru some research I found out the 2000 C5 LS1 had a .500 lift cam, I. & E.. 2000 C5 LS1s had the highest lift, and tighter LSA spec of 115.5°, of any base C5, base being the key, as the C5 Z06s had more lift in all years. I got it down to 12.50@114mph (OK, 113.9!) with Billy Boat shorty headers, which I thought was pretty quick for a stock internals LS1.....🌲🎅
Old Dec 8, 2021 | 04:57 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
My Corvettes at the track always seem to run the quickest right out the gate on the 1st run when the eng is coldest
I agree though running daily driver temps from about 185-200
Shocked to see my C7 run 225 all the time !!
Old Dec 9, 2021 | 09:36 AM
helga203's Avatar
helga203
You to Buddy.
Old Jun 9, 2022 | 11:09 PM
douglasjre's Avatar
douglasjre
I got HP Tuners w MPVI2, 160 tsat, and lowered hi speed fan to 190. I'm gonna lower it to 185. It makes more power now and the oil stays cooler and thicker as a result. My oil used to get up to 250f and thin out. Now oil is 212f. Not ever going back to those high temps.
To Power and engine temp?
