I would like to use a Corsa extreme cat back, but I have a full 3 inch setup. Corsa informed me they only offer 2.5, is anyone running a Corsa exhaust with a 3 inch X pipe if so did you have someone custom weld them together or is there an "easier" alternative.
Same with my Texas speed 3" x pipe. Easiest way to tell would be to see if your x pipe is advertised to work with the stock cat back. If it does, the corsas will work fine too
their flange bolts up to 3" system no problem, it necks down to 2.5" after the flange on the muffler side... if you want a true 3" then yeah you will have to do some modifying... it won't lose any noticeable power only being 2.5", I wouldn't worry about that personally
I’m not worried about power loss. My current setup is a No name 3 inch X pipe. On the website it says it bolts up to a 2.5. So you’re saying it’s actually a 3 inch flange? When I called they said it bolts up to the stock exhaust which would be 2.5 and they don’t offer 3 inch cross over pipes, which is why the kooks pipe is 3 inch but necks down to 2.5 to accept most axle back setups.
**** you're right, the neck down is on the header side so yeah it is a 2.5" flange... you would either have to weld a flange to neck it down to 2.5" on your midpipe or weld a 3" flange on the corsa over axel pipes
