As some of you may remember, I gave my 1997 C5 to my daughter in St. Louis. We think we have found a very honest, high-quality, reasonably-priced repair shop in a small town 30 minutes outside the metro area. The car has 180,000 miles on it which isn't high mileage for a 25-year old car but it is high mileage for a Corvette. What are some of the issues faced by a high-mileage Corvette?
My buddy and I have replaced the shocks with Z06 shocks, the power steering, the water pump, the rear wheel hubs and an assortment of other stuff. I am having the AC system pretty much completely redone this week.
The car burns some oil, which is either valves or rings. What are the typical high-mileage repair jobs which inevitably need to be done and what's a ballpark cost at a reasonably-priced Midwestern shop?
Thanks.
Jeff
Car is bone stock and gets regular Mobil 1 oil changes. Using the high mileage oil. Automatic.
My buddy and I changed the brake fluid the last time we changed the brakes. Had the coolant changed when the radiator was changed.
Good to hear the engines can keep running and running. I also really like that much of these cars are simply GM cars. Parts and labor are cheap compared to my BMW 645 which is now gone and the Porsche 928.
I'd probably also run it until I couldn't stand the oil issue and then either rebuild it myself in the garage with nothing fancy (re-ring kit and new valve seals as part of the cleanup) and throw the engine back in there.
Or, find a used LS motor and swap it in. An LS1 alum or iron block should drop right back in.
What does your daughter want to do with it? Just cruise around? Or something more aggressive like race it?
I thought it was really hot until I got my 2004 Z06 and then I understood why people buy Z06s. The '97 automatic is a grand touring car in comparison. My daughter DEFINITELY won't race it (although she totaled the 645 with a high-speed spin on an interstate in the rain). We have had it for 15 years and I hope she has it for 15 more years. Just stay on top of maintenance items and get them fixed when they need it. 1999corvettels1 had a good suggestion with the rear gear oil. To be honest, I don't know when that was done.
My big concern is the big costly engine or transmission repair. As long as they don't get too bad and she keeps it away from the stealership I am happy.
