endless air bubbles during auto bleed
Old Jul 19, 2021 | 06:58 PM
powertrain84's Avatar
powertrain84
Default endless air bubbles during auto bleed
new master, flex lines, pads, rotors, no signs of leaking anywhere. normal bleeding results in no air bubbles in waste line. during tech2 automated bleeding at the end of the cycle tons of air in waste line. did the process probably 10 times with same results. im guessing the abs moudule is some how sucking in air but not leaking out? any help would be much appreciated. pedal takes much more movement and pressure to engage the brakes as a lower mileage car.
