Pull key wait 10 seconds
Old Jul 19, 2021 | 08:46 PM
CLEAR's Avatar
CLEAR
Default Pull key wait 10 seconds
I have a newly acquired 99 and a majority of the time I start it I get the dreaded pull key message and it dies.
It has had the recall
It does have the lmc5
I have cleaned the key pellet
Now what?
Old Jul 19, 2021 | 08:50 PM
CLEAR's Avatar
CLEAR
And I just went to move it after this post ans got the service column lock message
Old Jul 19, 2021 | 09:00 PM
OU812!'s Avatar
OU812!
You can avoid this if as soon as you sit down turn the key on but do not start it. Get your seat in position and seatbelt on then start. I have the same issue from time to time and its does not like trying to insert key and start really fast. I have the bypass too so don't worry about being stranded. Just give it 5secs or so once you put the key in and try to start.
Old Jul 19, 2021 | 09:54 PM
Smoken1's Avatar
Smoken1
How old is your battery? Did you do the brown wire mod listed on page 2 of the instructions?
Old Jul 19, 2021 | 10:00 PM
CLEAR's Avatar
CLEAR
Not sure on brown wire. It was installed when I got the car. Battery voltage at 13.1
Old Jul 19, 2021 | 10:04 PM
Smoken1's Avatar
Smoken1
If it is the old version that does not have the brown wire mod call Richard at http://complianceparts.com he will help you out and let you know what options you have
Old Jul 19, 2021 | 10:10 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
need someone with HP tuners to turn off that fuel shut off crap if thats whats happening...
.I had the CLB in my car and never had these issues thenI had just had the fuel shut off crap turned off during a tune later on so it never became an issue
Old Jul 19, 2021 | 10:42 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
I got the service column lock message recently and was still.able to drive it because I had a tune from ECS. It happened after the car was sitting for awhile. When I went to start the car it cranked a bit and I shut it off before it started, but then immediately started it. After that the service column lock message came up. The column lock would not do anything when I started the car or shut it off. Disconnecting and reconnecting the battery seems to have fixed it for now It looks like my battery may be an issue. Voltage seems to be a little low. I bought a LMC5 and will install it when I get a chance.
Old Jul 20, 2021 | 04:37 PM
CLEAR's Avatar
CLEAR
Called Richard. He told me to go ahead and do the brown wire. I’ll report back.
Super guy to speak with FYI.
Old Jul 21, 2021 | 08:16 AM
pauly1119's Avatar
pauly1119
St. Jude Donor '06-'11
Old Jul 21, 2021 | 08:49 AM
Moved to C5 Tech.
To Pull key wait 10 seconds
