Engine harness swap and p1518 code
DTC report
Selected brand: Chevrolet
============1==============
P1518
Raw code: 1518
ECU: 10
Status: Pending
OBDII: Intake Manifold Runner Control (Stuck Open)
Chevrolet: Throttle Actuator Control (TAC) Module Serial Data Circuit; Electronic Throttle Module to PCM Communication
============2==============
P1518
Raw code: 1518
ECU: 10
Status: Confirmed
If i unplug the tac module from the pcm the car will start and idle without backfiring but its a little high. And throttle pedal seems to be dead wether its hooked up or not. I drove this car since may 5th of this year with my only issue being burnt ignition switch contacts, so i know the tac module APP and TPS are good. And its a brand new harness. throttle body and tac pins look perfect, and i haven't messed with the app yet. Anyone got any ideas what my problem might be?
