TPS sensor
Old Jul 20, 2021 | 04:30 PM
Y2kyellowvette's Avatar
Y2kyellowvette
1st Gear
Default TPS sensor
Had an overheating problem, put in new waterpump, car ran fine but Reduced Engine Power comes on DIC and throws coes P1120 and P1220 throttle postion sensor voltage low. Is this causing the reduced engine power signal?
Old Jul 20, 2021 | 05:03 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
First off welcome to the Forum. Second, can you fill in your profile especially model year and mods, tune ??...there are minor wiring differences between model years. These 2 DTC's will cause a REP...The 1120 is for TPS 1 and the 1220 is for TPS 2...the computer is seeing lower or higher voltages than than expected...with this overheat did any coolant get escape ??...if so you should remove the TPS sensor and even the TAC module and look for water intrusion. Not knowing if you have a DVOM or what your electrical skills are I'll hold off on helping you check the 2 TPS signal wires to see what voltages you have there. I'd remove the TPS sensor and check for pin fitment initially and fuse #17 (THROT CONT) in the underhood box.
