E-Brake Ratchet Help
Old Jul 22, 2021 | 09:34 PM
adrielius's Avatar
adrielius
Default E-Brake Ratchet Help
Looking for some advice; my e-brake suddenly won't ratchet or stay in place in anymore.
I took the seat out and removed it, something seems off inside the welded metal mechanism.
Searching around online, the common solution is to just replace the entire e-brake.
Is there a way to fix it, or should will I have to just replace it?
Thanks in advance!
Old Jul 23, 2021 | 12:16 AM
jim993's Avatar
jim993
Default Park Brake
That happened to me about ten years ago. Upon detailed examination of the park brake mechanism, I found that the heavy, stiff steel wire that connects from the push button to the ratchet mechanism has a loop at the lower end which can be deformed by pushing hard on the button without FIRST pulling back on the lever to relieve pressure on the ratchet. I concluded that I could fix it, but that effort would require major steel surgery on the park brake mechanism.
I bought a good used park brake mechanism and saved the old one for a future project.
Old Jul 23, 2021 | 12:49 PM
adrielius's Avatar
adrielius
Thanks for the insight! Now to track down a new e-brake.
Old Jul 23, 2021 | 03:05 PM
jgump's Avatar
jgump
I have a used parking brake assy. I'll do $60 plus shipping if you are interested. Thanks.
Old Jul 23, 2021 | 03:49 PM
adrielius's Avatar
adrielius
Oh, I just snagged one off eBay this morning... If that doesn't work out I'll take you up on the offer, thanks!
To E-Brake Ratchet Help
