C5 2000
Old Jul 30, 2021 | 03:43 PM
Turneradt's Avatar
Turneradt
Navigator
Default C5 2000
I have a 2000 Corvette my ABS light and Traction Light comes on then goes off if I turn the car off and restart but comes back on after awhile..... Assistance plz?
Old Jul 30, 2021 | 04:23 PM
helga203's Avatar
helga203
check codes if u have 1255 ur screwed. i think.
Old Jul 30, 2021 | 04:37 PM
Smoken1's Avatar
Smoken1
Use the DIC and pull your codes
Old Jul 30, 2021 | 04:46 PM
Turneradt's Avatar
Turneradt
Navigator
Why do you say I'm screwed if it's a 1255 code...?
Old Jul 30, 2021 | 05:46 PM
Smoken1's Avatar
Smoken1
The 1255 code is usually the death code of your EBCM but, there is about 2 dozen other codes that will trigger that light to come on
Here is how to pull your codes
Old Jul 30, 2021 | 07:18 PM
Turneradt's Avatar
Turneradt
Navigator
Forgot to say it doesn't stay ON ...
Old Jul 30, 2021 | 07:33 PM
Smoken1's Avatar
Smoken1
You can pull the codes while the car is running to see what current codes you have.
Old Jul 30, 2021 | 07:38 PM
Turneradt's Avatar
Turneradt
Navigator
OK ~ Thank you...
Old Jul 31, 2021 | 12:52 PM
Turneradt's Avatar
Turneradt
Navigator
here's some codes I pulled...
AO-LDCM B2252-2202-2282-2284-2262-U1255-U1064-U1016-U1096-
A1-RDCM-B2283-B2285H-B2265-U1255-U1064-U1016-U1096
Old Jul 31, 2021 | 01:02 PM
grinder11's Avatar
grinder11
OK ~ Thank you...
Do you ever see "Active Handling Warming Up"? Just asking, because the steering sensor can cause a "Service Traction Control" and "Service Active Handling". Don't mean to confuse you, because you're getting a "Service ABS System" code, which isn't exactly the same. I have a 2000 Vert. If your EBCM is trash, there's a sticky on how to upgrade to an '01-'04 EBCM, which are still available new (last I knew!). The EBCM for our cars ('97-'00) is no longer available new. They're available only in salvage yards, used. They are also usually at least $1,000.00!!! So, as posted above, the 1255 code is a bad thing. But it could also be a connection/wiring issue, so before you trash it, make sure you check out everything!!
Old Jul 31, 2021 | 01:10 PM
Turneradt's Avatar
Turneradt
Navigator
The ABS and Service Traction Control is displayed....
Old Jul 31, 2021 | 03:24 PM
grinder11's Avatar
grinder11
Yup, the ABS code is the most important one, for sure. You can probably clear the DIC after a few miles, but the yellow ABS and skidding Corvette lights will still be on. Sorry to hear about the 1255. I have a 2000, and it's kinda scary thinking about that 1255 code!! As much of a PITA as this code is, not to mention the price, and risk, of buying a used one, maybe we '97-'00 owners should start holding funeral services for our EBCMs!!!
Old Jul 31, 2021 | 04:38 PM
Smoken1's Avatar
Smoken1
All the U codes are communication problems in the Serial Data Line and seem to be confined to the Left and Right door control modules
I would check you grounds https://www.corvetteforum.com/forums...tml?forum_id=1
and the connections in the accordion tube
File Type: pdf
Old Aug 1, 2021 | 10:47 PM
Turneradt's Avatar
Turneradt
Navigator
Thank you very much...Will try this tomorrow raining today live in apartment no garage.... Lol
Old Aug 17, 2021 | 04:54 PM
Turneradt's Avatar
Turneradt
Navigator
Good Afternoon ~ Anyone know where I can get a ABS Modulator Valve for a 2000 Corvette C5? Appreciated !!
To C5 2000
