Abs part 10343433
Old Jul 31, 2021 | 11:16 AM
dt1759's Avatar
dt1759
Cruising
Default Abs part 10343433
I have searched and searched for this module 10343433 . Found one and the same codes are appearing , apparently not a valid part . Any thoughts ? This will not calibrate and I’m at a loss .2004 convertible
started with steering angle sensor all good , wheel sensors all good , locks up to the left at times which led to ABS
Old Jul 31, 2021 | 11:53 AM
Autotragic's Avatar
Autotragic
What ABS code/s are you getting on your DIC?
1) Turn on the ignition but don't start the engine.
2) Press the "reset" button to turn off any warning messages
3) Press and hold "options" and
4) While holding "options", press "fuel" four times within a 10-Second period.
Initially, the on-board diagnostics go into the "automatic" mode, which shows each module's DTCs in a
pre-set sequence: (Page No. are for the GM Service Manual)
10 PCNI Powertrain Control Module page 6-357 - 6-361
28 TCS Traction Control system ABS on page 5-86
?? RTD Real Time damping page 3-136
40 BCM Body Control Module page 8-405 LTD Page 8-727
60 [PC instrument Pane! Cluster page 8-508
80 radio page 8-213
99 FIVAC Heater Vent-Air Conditioning page 1-118
A0 LDCM Left Door Control module page 8-904 to 8-951
Al RDCM Right Door Control Module page 8-904 to 8-951
AC SCM Seat Control module page 8-1064-8-1082
B0 RFA Remote Function Actuation page 8-676
https://www.corvetteforum.com/forums...odes-dtcs.html
Old Jul 31, 2021 | 12:52 PM
dt1759's Avatar
dt1759
Cruising
Thanks I will keep
Old Jul 31, 2021 | 03:52 PM
dt1759's Avatar
dt1759
Cruising
Default Abs pary
80 radio page 8-213
[url]https://www.corvetteforum.com/forums/c5-tech/3080263-diagnostic-trouble-codes-dtcs.html
thanks but the dealer working on is closed til Monday so I do t have codes
Old Jul 31, 2021 | 10:58 PM
Moved to C5 Tech.
Old Aug 2, 2021 | 03:03 PM
dt1759's Avatar
dt1759
Cruising
Default 10343433
Thanks for all the info but the tech working on it cannot get it to take . I’m really at a loss , frustrated and not knowing what to do next . They are extremely reputable but can’t figure this one out
Old Aug 2, 2021 | 03:38 PM
rhneff's Avatar
rhneff
Maybe just me but I'm having a hard time understanding exactly what the nature of the problem is that you're trying to address - "locks up to the left at times which led to ABS"??
10343433 is the correct part number for the AC Delco ABS control module for the C5 and there are a number of sellers on the internet that seem to have that item available, but depending on the nature of the issue you could also just remove the module and send it to abxfixer (google it) to have it repaired probably at a lower cost.
Old Aug 2, 2021 | 04:15 PM
dt1759's Avatar
dt1759
Cruising
Default Abs
locked up meant pulled left for a quick moment after maybe hitting a rough road or bump . Initially thought the steering angle sensor but I have been told all wheel sensors are good and steering angle good and all leads to ABS module . I found a rather expensive one which is what’s in there now trying to get calibrated , a repair could be the next option . I also have Ben told they only need the electrical portion of the module but ...
Old Aug 2, 2021 | 04:32 PM
dt1759's Avatar
dt1759
Cruising
I just found out the codes were c1287 and c1288
Old Aug 2, 2021 | 04:42 PM
Smoken1's Avatar
Smoken1
You need a new SWPS
Hope you have an 01-04 car as they are still available
Old Aug 2, 2021 | 04:45 PM
dt1759's Avatar
dt1759
Cruising
Originally Posted by Smoken1
You need a new SWPS
swps ?
Old Aug 2, 2021 | 04:50 PM
dt1759's Avatar
dt1759
Cruising
swps ?
we changed the steering angle sensor and codes still appeared is that the same as swps ?
Old Aug 2, 2021 | 05:20 PM
Smoken1's Avatar
Smoken1
Maybe, was the one you replaced at the bottom of the steering column and was it a new GM part?
Old Aug 2, 2021 | 05:55 PM
dt1759's Avatar
dt1759
Cruising
yes it was
Old Aug 2, 2021 | 06:53 PM
Smoken1's Avatar
Smoken1
yes it was
Check the connection to it for bent or spread apart pins
Old Aug 2, 2021 | 06:55 PM
dt1759's Avatar
dt1759
Cruising
got it thanks
To Abs part 10343433
