Tech Tips - Blackwing install...
Old Dec 19, 2002 | 08:50 AM
C5Ken's Avatar
C5Ken
Default Tech Tips - Blackwing install...
I'm looking for a step-by-step procedure to remove the factory air filter & install a Blackwing on a 2001. Tech Tips has a procedure with lots of pictures but little verbiage. I need more detail. Any idea where I can get a detailed procedure? :confused: :confused:
Old Dec 19, 2002 | 10:11 AM
FYNL4's Avatar
FYNL4
Default Re: Tech Tips - Blackwing install... (C5Ken)
I'm not sure what you looked at but this procedure is the best I've seen, http://www.c5forum.com/diy/donaldson.php
I just installed one this past weekend and these instructions were more than adequate. It is a really easy procedure once you get started. Took me about 30 mins from start to finish and it was the first time I ever touched my engine. You can do it, just go for it.... You can't get in any real trouble with this modification. Good luck.......... :thumbs:
Old Dec 19, 2002 | 10:39 AM
RogueVette's Avatar
RogueVette
Cruise-In III Veteran
Default Re: Tech Tips - Blackwing install... (FYNL4)
:iagree: It took me about 20 mins. the hardest part is getting the blackwing over the gromets that go up front. I found the easiest way was too unscrew the gromets from the shroud and insert them in the blackwing, then screw them back in. Just remember to unhook both the connections my brother ripped one of his off :) otherwise it's a very easy install
Old Dec 19, 2002 | 11:47 AM
DsC5's Avatar
DsC5
the tech tip above is actually very helpful. it is nearly impossible to screw it up once you get started - and the tech tip becomes clear as you get going. it more or less comes down to taking the stock filter and housing out and putting the blackwing in. it's really that simple. :seeya
Old Dec 19, 2002 | 12:26 PM
Tom337's Avatar
Tom337
https://www.corvetteforum.com/techti...D=76&TopicID=1
Old Dec 20, 2002 | 09:53 AM
C5Ken's Avatar
C5Ken
FYNL4
Thanks for the info. This is just what I'v been looking for.
Old Dec 20, 2002 | 11:01 AM
FYNL4's Avatar
FYNL4
Glad to help, good luck............
Old Dec 21, 2002 | 12:29 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Follow the above tech tips, but even without them I think that you could easily understand and perform the install. Just look at what you have as stock, and what new is going in, and you will be able to do it fine.
It's a great mod. Good luck and enjoy.
Old Dec 21, 2002 | 11:17 AM
RHILL's Avatar
RHILL
Default Re: Tech Tips - Blackwing install... (FunDriver)
Tech tip for a blackwing :confused: you only have one hose clamp :cheers:
To Tech Tips - Blackwing install...
