AC Not Working
Old Aug 9, 2021 | 07:04 AM
Turbo Bob's Avatar
Turbo Bob
Corvette Challenge Champ-01
Dragster Challenge Champ-06
Default AC Not Working
Good Morning. Coming home from Island Dragway this past Saturday night put the AC on on my 1998 Corvette. AC button on dash blinked a few times then turned off. No AC. Scanned for codes. No codes present. Already checked number 24 10 amp fuse on fuse block under hood. It was fine. Low on Freon? Any ideas? TIA.
Old Aug 9, 2021 | 08:09 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
First thought would be low Freon however there are other things that can cause this…if it’s low on Freon you probably have a leak somewhere so that should be addressed first !!…is this Island Dragway in Great Meadows, NJ ???
Old Aug 9, 2021 | 09:05 PM
Turbo Bob's Avatar
Turbo Bob
Will check it for leaks. Yes Island Dragway in Great Meadows NJ
Old Aug 9, 2021 | 09:44 PM
C5 Diag's Avatar
C5 Diag
OK Great !!…back in the 60’s/70’s my cousins in-laws owned it…spent a lot of time there on the track and in the tower !!
Old Aug 10, 2021 | 08:01 AM
Turbo Bob's Avatar
Turbo Bob
That would be Eddie Kowalick.
Old Aug 10, 2021 | 08:56 AM
C5 Diag's Avatar
C5 Diag
Yes, and I believe the family still runs it !!
Old Aug 10, 2021 | 11:05 AM
Turbo Bob's Avatar
Turbo Bob
Yes. Kathy’s daughter Melissa and husband Carl run it.
Old Aug 12, 2021 | 12:25 PM
Speedy007's Avatar
Speedy007
Just go get a bottle of your choice at your local store of the r131a or whatever it’s called feon….hook up the gauge to your low pressure rear most towards the fire wall .. make sure your a/c is on full blast or u will read high pressure so make sure the light for the a/c is on and measure what’s the reading , chances are it’s low due to age and very small seeping from the valve stem you’ll see once u remove the cap look for wetness …just refill with the stop leak stuff …and u should be fine for the next 10 years
Old Aug 16, 2021 | 09:09 AM
Turbo Bob's Avatar
Turbo Bob
My friend is HVAC guy. Brought over tank of R134. We tried to charge the system but while putting Freon in we heard it hissing out below low side fitting. Now we have to put it up on lift to find leak or crack in line below headers.
To AC Not Working
