Service Traction Sys and ABS (with codes)....
Old Dec 19, 2002 | 11:21 AM
Steak's Avatar
Steak
5th Gear
Default Service Traction Sys and ABS (with codes)....
First off, love this place, don't post much, but this is a fantastic place for information. Kudos to all involved =)
Now, for my newest problem.....
My 98 coupe will throw the Service Traction Sys and Service ABS dummy lights on the dash and the DIC once in a while. After paying attention to the problem, I've narrowed it down to when I turn the wheel hard (parking lot manuvers) and if I hit a bump (also parking lot manuvers, sheesh, maybe I should never park this rascal...). Did some research, found out how to display the service codes on the DIC. Ok, any of you mechanics want to translate this to english for me? And give me a rough idea of how much trouble ($) I am in for when I take this to a dealership?
28-TCS
C1225H RF Excessive Wheel Speed Variation
C1226H LF Excessive Wheel Speed Variation
C1255H EBTCM Internal Malfunction
I know the H means history, though I can make the car do this everytime I drive it. The problems at the wheel speed sensors follows with the turning of the steering wheel causing problems. The one the really gives me the shakes is the last code. It just sounds expensive.
Edit-Spelling errors :bb
[Modified by Steak, 4:24 PM 12/19/2002]
Old Dec 19, 2002 | 11:33 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Service Traction Sys and ABS (with codes).... (Steak)
This could be a faulty Wheel bearing or a bad ground on your rubber brake line. Within the codes, does it say which wheel is giving you the problem?
vetterdstr :cheers:
Old Dec 19, 2002 | 12:12 PM
Steak's Avatar
Steak
5th Gear
Default Re: Service Traction Sys and ABS (vetterdstr)
Near as I can tell, both front wheels are causing code troubles....
Old Dec 19, 2002 | 12:16 PM
leonm47's Avatar
leonm47
Just got mine done three weeks ago very same problem each time I hit a bump. it was the front wheel hub. The part is $724 but I have 1 Source extended warranty. My cost$00.00.
To Service Traction Sys and ABS (with codes)....
