2000 C5 Traction Control Module #19244084
Old Aug 19, 2021 | 09:34 AM
Slip1in's Avatar
Slip1in
2nd Gear
Default 2000 C5 Traction Control Module #19244084
New here, hoping to find ebcm # 19244084 for my 2000 C5 - IF NOT - how to remove the skid icon off the dash…
Old Aug 19, 2021 | 09:57 AM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the Forum, Bob, and congratulations on your C5!
This is more of a "Hello" section. I would suggest placing your need for an EBCM in the C5 Parts for Sale/Wanted section, and ask the question about removing the skid icon in the C5 General section. Both are in: https://www.corvetteforum.com/forums...s-1997-2004-2/. You find lots of great members and helpful info there that may be of benefit as you continue to enjoy your C5.
Best wishes with finding your EBCM.
Old Aug 19, 2021 | 10:40 AM
Slip1in's Avatar
Slip1in
2nd Gear
Thank you for your help… this is the nice thing about a forum!!!👍👍👍❤️
Old Aug 19, 2021 | 11:49 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Moved you here
Old Aug 19, 2021 | 06:49 PM
RedRiderZR1's Avatar
RedRiderZR1
Welcome to the forum.
That light can be caused by many things without it being a bad EBCM. It talks to sensors on the vehicle. If one of those sensors is having a reading problem then it will illuminate that light. For instance, It can be the sensor or a wiring issue. The C5 can show the codes that are stored in the vehicle. The first thing you should do is post the codes you find on here so people can help you diagnose the problem. The section for the EBCM is under TCS in the menu. I will add a video below to show you how to do that.
To 2000 C5 Traction Control Module #19244084
