Radiator Cap question
Old Aug 20, 2021 | 10:29 AM
UM Rebel's Avatar
UM Rebel
Default Radiator Cap question
Does anyone know why specification on radiator cap was changed from 15 psi to 18 psi?
Old Aug 20, 2021 | 11:57 AM
grinder11's Avatar
grinder11
Probably to increase the boiling point of the coolant.
Old Aug 20, 2021 | 12:17 PM
rrwirsi's Avatar
rrwirsi
Found this on the 'Net'. Not an answer from GM but some of it seems to make sense.
radiator - Why did GM change the pressure rating of their coolant tank cap for existing vehicles? - Motor Vehicle Maintenance & Repair Stack Exchange
Old Aug 23, 2021 | 09:11 AM
grinder11's Avatar
grinder11
How would the OP (or I) know which cap is 15psi, and which is 18psi? After seeing this thread, I went out to the garage and removed my cap. I can't find a part# on it anywhere, on the bottom, top, or around it. Any suggestions for us?
Old Aug 23, 2021 | 09:40 AM
rrwirsi's Avatar
rrwirsi
I checked the original cap that I replaced with a 18psi and the yellow label on the top clearly indicates 15psi. Possibly yours grinder11 may have been replaced by a previous owner. The new cap is clearly marked 18psi.
Old Aug 23, 2021 | 11:38 AM
grinder11's Avatar
grinder11
I bought the car at the 23,000 mile mark, so I'm assuming it's the OEM cap. I'll re-check......
Old Aug 23, 2021 | 07:23 PM
grinder11's Avatar
grinder11
OK, went out to check cap, and there's no decal/sticker (anymore?). I ran Evans coolant at one time years ago, and it came with a sticker for the cap warning against adding any water to the coolant. I removed the sticker about 7 years ago when I went to Dex Cool. I may have pulled the original sticker off with it. If so, I didn't notice. My cap is all black, and only says "Warning, Do Not Remove Hot". That's it. I'm not having any boil over issues, or overheating issues, so I guess I'll leave it alone. Would just like to know.........
Old Aug 23, 2021 | 07:41 PM
Smoken1's Avatar
Smoken1
Take the cap down to a auto parts store and have it tested
Old Aug 24, 2021 | 09:46 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
Just replaced my cap. Original 99 was 15 psi, new cap 18 psi.
Old Aug 25, 2021 | 09:43 AM
grinder11's Avatar
grinder11
I wonder what model year they went to the 18psi cap? Anyway, I think I'll take smoken1s advice, and have it tested. If I need a new one, I guess I'm a lucky guy, because I've certainly replaced more expensive parts on it!!!
To Radiator Cap question
