Any experience or thoughts with these electrical issues?
1) driver door won’t lock with the fob. It sounds like the doors are locking when you use to lock button, however you can still open the driver door and the alarm goes off.
2) when I start the car I get a “charge fault” error on the dash.
3) driver power seat won’t work...at one point was draining the battery so he unplugged the fuse. I assume the entire power seat mechanism could be replaced, not sure if that’s expensive or not.
thanks so much guys!
The System Charge Fault could be due to a failing battery. Have the battery load tested. AutoZone does it for free. Battery age doesn't matter. A battery can fail at any age.
The seat issue could be any number of items. I'd investigate to see if one of the functions is stuck. Move the seat to various positions and see if it stays there. Also listen for the lumbar pump if you have sport seats.
The C5 seat switch assembly is known for failing and causing battery drain. $150 part, available from multiple outlets.
