Any difference between an auto or manual c5 ring and pinion.Im asking cause i need a new r&p and it says on web site for nitro 3.42 gears for manual cars only,how can that be?
They probably just say that to reduce the number of complaints from people that have 2.73 gears/carriers wondering why those gears won't fit.
But believe it or not there is a spacer available that will let you mount lower (numerically higher) gears in a 2.73 carrier but I've never heard of anyone actually using it on these forums.
Motive Gear M52012530-1 - Differential Ring Gear Conversion Spacer
I broke a couple of teeth off the ring and pinion,so just replacing with the same,just wanted to go with nitro r&p,and i just realized the rear was from a manual car,duh lol.thanks guys
