HAVC removal
Old Sep 14, 2021 | 05:11 PM
2010Pony's Avatar
2010Pony
Default HAVC removal
Going to take my unit out and send it in for repairs are there any tricks I need to know about. 2000 Convertible
Old Sep 14, 2021 | 05:40 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Easy enough to do. If your car is stock the only tools needed are a T15, a deep 10mm socket, a 7mm socket, a steady hand, and a flat blade screwdriver to undo the clips at the cigarette lighters, gas door release, etc.
Two 10mm are hidden under the caps when you open the center console.
The other two are under the Active Handling panel.
A T15 is under the interior temp sensor to the left of the ignition lock cylinder.
Two T15s are under the ash tray door flap.
Pry gently. It comes apart easily.
I've been in there a few times...
Old Sep 14, 2021 | 06:12 PM
DDaaryl's Avatar
DDaaryl
There are a few videos on line that describe both the removal and repair. Personally I thought the repair (for dim lights) was easier than the removal. I have found Google is easier than the search feature on this site.
Old Sep 14, 2021 | 07:01 PM
popshumphrey's Avatar
popshumphrey
St. Jude Donor '16
Old Sep 14, 2021 | 07:06 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
pretty straight forward as stated....few screws and about 30 minutes tops
Old Sep 14, 2021 | 08:31 PM
2010Pony's Avatar
2010Pony
Thanks but what is a T15?, looks like a little work. Be going to Florida for the winter and found a place in Tampa that wii rebuild it for $210.. Do you know if this would cause the A/C not to work, you can’t see anything , but the blower and heater will work. Love this ride had a 64,65,66 & 88
Old Sep 14, 2021 | 08:48 PM
Stingroo's Avatar
Stingroo
Torx. If you don't have a set, you can get them pretty cheap from Harbor Freight.
Old Sep 16, 2021 | 02:02 PM
Moved to C5 Tech.
Old Oct 12, 2021 | 05:09 PM
2010Pony's Avatar
2010Pony
All went well in removal of HAVC unit except had to remove waterfall, and lost one screw. Shifter **** also came out good even with the demon key
Old Oct 12, 2021 | 05:28 PM
Smoken1's Avatar
Smoken1
If you can solder it is a pretty easy repair for the dim or dark screen problem
Old Oct 12, 2021 | 06:18 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
There are a few issues that would cause your AC not to work…not just a bad HVAC module !!…would be bad if you spent a lot to rebuild the module and still have no AC…what are you seeing which makes you believe the module is bad ??
Old Oct 12, 2021 | 06:36 PM
2010Pony's Avatar
2010Pony
That’s the problem, I can’t see anything at all
Old Oct 12, 2021 | 07:13 PM
C5 Diag's Avatar
C5 Diag
Oh, as in the display is blank…OK !!
To HAVC removal
