Horn quit when using fob
The horn does work when pressed on the steering wheel....
Any Ideas?
Here is the info from my manual.
Lock and Arm
Press the OPTIONS button until LOCK & ARM appears
on the display, then use the RESET button to page
through the following selections:
• LOCK & ARM – OFF
• LOCK & ARM – HORN ONLY
• LOCK & ARM – LIGHTS ONLY
• LOCK & ARM – HORN & LIGHTS
If you choose LOCK & ARM – OFF, you will receive no
security feedback when locking or unlocking your vehicle.
If you choose LOCK & ARM – HORN ONLY, only the
horn will chirp to let you know when your alarm system
has armed when locking your vehicle.
If you choose LOCK & ARM – LIGHTS ONLY, only your
exterior lamps will flash to let you know when your
alarm system has armed when locking your vehicle.
If you choose LOCK & ARM – HORN & LIGHTS, the horn
will chirp and the exterior lamps will flash briefly to let you
know the system has armed when locking your vehicle
