Sagging front end, help??
Old Sep 22, 2021 | 10:20 AM
lamaro88's Avatar
lamaro88
Default Sagging front end, help??
I have a 2002 zo6 and I realized about 2 months ago that the front passenger side is sagging a bit. You can tell the difference by looking at it from the front and also when I sit in the drivers seat, its not even. I tried researching what it could be but haven't really found much. Anybody else have this issue in the past? I recently changed out the shocks, tie rods, sway links, and I checked the stock lowering bolts, their the same on both sides. The car has been aligned already.
Old Sep 22, 2021 | 08:55 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
If the spring isn't cracked or broken start adjusting until it's where you want it.
Old Sep 22, 2021 | 11:06 PM
gimp's Avatar
gimp
One easy thing to do also is to drive the car (so the suspension settles) and put it on even, flat ground. Measure 1) from the tops of the tires to the bottom of the wheel arch (at the highest point), and 2) from the ground to the jacking points. If you see a significant disparity between right and left, you have a problem.
At this age, a lot of springs have failed. They might not be visibly cracked or failed when you get under the car, but you may lift the car and just find that the spring is not behaving properly. You may need a spring replacement. Of course it is possible that at some point, someone adjusted the ride height improperly and you only now noticed. If you believe that this never happened, an actual hardware failure is, I think, more likely than the ride height simply changing by itself from you driving. There are other components that may have failed that cause this, but I'd look there first -- after measuring to confirm your theory.
Old Sep 25, 2021 | 06:30 AM
Moved to C5 Tech.
Old Sep 25, 2021 | 09:57 AM
lamaro88's Avatar
lamaro88
The car was sagging before I replaced the shocks, tie rods, and sway links. I did drive it around after I got the alignment to see if it would settle or if anything would change but nope. I will try to measure today and see what I find. By adjusting the ride height do you mean stock lowering bolts? I did check those when I was working on the car, and I reset them and lowered them to the same length on both sides. Thanks for your response, I will try to measure today.
Old Sep 25, 2021 | 10:37 AM
helga203's Avatar
helga203
Im experience is that replacing the shock will not affect any other components, expect if shock is bad. If ur adjustments don't work i would swap shock to the other side. Yes i would b a pain, but that would confirm its the shock. But usually if it not leaking their good to go but u never know if its a defect.
Old Sep 25, 2021 | 07:36 PM
Bill Dearborn's Avatar
Bill Dearborn
Make sure the problem isn't a sagging fender that needs to be realigned. Check the body panels and the suspension height from the ground to see if the fender has become loose/tilted. Just went through this on a C7Z when the front track tire started rubbing the fender and wearing out parts that shouldn't wear.
Bill
Old Sep 26, 2021 | 12:55 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
OP, keep in mind, that an issue in the rear, could manifest itself in the front. My suggestion would be to check the ride height at all 4 corners. And while many people use the "wheel opening height method", as it's "quick and dirty", it isn't always 100% accurate. The factory shop manual calls out ride height measurements be taken at the inner pivot bolts for the lower a-arms.
To Sagging front end, help??
