timing chain info
Old Sep 22, 2021 | 08:04 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
Default timing chain info
Could someone send me in the right direction?
2001 base 5.7 eng. replacing my timig chain and would like to find a chain tensior brackett,
my 01 does not have the holes drilled in the block for the tensioner. I have the one piece
tensioner that goes between the gears and looks like it holds the chain on both sides.
Thaks, mike venth
Old Sep 22, 2021 | 08:32 PM
Smoken1's Avatar
Smoken1
This is the only piece that I know of for our cars
https://briantooleyracing.com/rde-ti...rde-62188.html
I have one on my 02 I also went with a better timing chain
https://www.corvetteforum.com/forums...-no-equal.html
Old Sep 22, 2021 | 09:32 PM
mike venth's Avatar
mike venth
mike v
I have the tensior ,, looking for the brackett that holds it on, mine does not have the holes drilled.
Old Sep 22, 2021 | 09:35 PM
mike venth's Avatar
mike venth
mike v
I have new chain, and gear and it came with the tensior. Talking with Bill C, he said that they have a brackett to hold it that bolts to the cam holder plate.
Old Sep 22, 2021 | 10:01 PM
mike venth's Avatar
mike venth
mike v
Thanks guys for your input. I found this product for my chain tensior
Trick Flow Specialties TFS-30675600 - Trick Flow® Timing Chain Adapter Brackets for GM LS
Old Sep 23, 2021 | 11:18 AM
mike venth's Avatar
mike venth
mike v
Working with Bill Curlee he said that with the big cam, duel springs, roller rockers, melling pump, ported /polished heads, headers that
I should use a tensior. The new chain, gears came with it anyway. I talked to Bill yesterday and told him that the block was not drilled for the tensior,
so he said that there was a adapter out there that would solve that. Bill has been a great help over the years and, so when I'm dealing with a problem
or making upgrades he is right there to help me.
Thanks Bill and the forum members for all your help.
Mike Venth
Old Sep 23, 2021 | 02:30 PM
G_Loc's Avatar
G_Loc
At the risk of sounding pedantic, that's a damper, not a tensioner. A tensioner puts tension on the chain while a damper just stops it from whipping around.
That being said, make sure to stick with the torque specs when tightening the button head screws as the metal seems kind of soft.
Old Sep 23, 2021 | 02:54 PM
mike venth's Avatar
mike venth
mike v
Thanks G Loc,,, I stand corrected. Hope the taque specs are in the directions, if not should I use the factory taque specs?
hanks again.
Mike Venth
Old Sep 23, 2021 | 03:24 PM
G_Loc's Avatar
G_Loc
They're in the instructions - 15-18 ft-lbs. I just installed this kit a few days ago and tightened them to about 17 ft-lbs. Make sure to Loctite everything!
One more thing: does your existing camshaft retainer plate have recessed bolt holes? I forgot when they switched to this style.
Old Sep 23, 2021 | 04:00 PM
Rx7Rob's Avatar
Rx7Rob
I'm using that on my car. No issues after 9 years and many track days!
Old Sep 23, 2021 | 05:03 PM
mike venth's Avatar
mike venth
mike v
Good question??? I'll look now, and thanks for the updates...
Old Sep 23, 2021 | 05:13 PM
_zebra's Avatar
_zebra
if that don't work out, Bret (BLOWNBLUEZ06) also makes a good heavy duty timing set.
Old Sep 23, 2021 | 05:36 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I put one in my car, several years back, along with an LS2 chain.
Old Sep 23, 2021 | 07:28 PM
mike venth's Avatar
mike venth
mike v
G Loc My camshaft retainer plate does Not have recessed bolt holes. Would you know what year and what model had it.
I have a machine shop and could recess them myself. This is my first LS Eng. build, learning alot.
Old Sep 23, 2021 | 07:53 PM
Smoken1's Avatar
Smoken1
My 2002 vert has that style plate. Somewhere in in the 01 GM switched over to using LS6 blocks that's probably why my 02 has the holes drilled the taped for that damper your installing
Old Sep 23, 2021 | 08:39 PM
G_Loc's Avatar
G_Loc
No need to do that, you're good. Reason I asked is that I found a post or two somewhere expressing concern about using this adapter with the style that has recessed holes. You should go ahead and replace it anyways (if you haven't already). Mahle makes one, part # B31822
Old Sep 24, 2021 | 09:08 AM
mike venth's Avatar
mike venth
mike v
The plate will be here by the end of the day. Be heading to the auto parts store later on and pick up the new cam plate also.
Thanks for all the great info folks, made this project go a lot smother.
Mike V
Old Sep 24, 2021 | 09:21 AM
grinder11's Avatar
grinder11
My 2000 LS1 had the countersunk holes for flathead screws........
Old Sep 24, 2021 | 05:42 PM
leadfoot4's Avatar
leadfoot4
IIRC, mine did too, but the OE damper wasn't available at the time.
To timing chain info
