Help! 2002 is stone dead.
Old Sep 24, 2021 | 12:59 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Default Help! 2002 is stone dead.
Battery is fully charged. Starter won't even click. No dash lights. When you hit the key with a meter on the battery voltage does not change. Last driven 1 week ago, no issues. Sitting in the garage.
Any thoughts?
Thanks!
Old Sep 24, 2021 | 01:00 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
ignition switch
Old Sep 24, 2021 | 01:30 PM
claysmoker's Avatar
claysmoker
Originally Posted by itsonlyairandfuel
ignition switch
I thought about that. Hope you're wrong.
Old Sep 24, 2021 | 01:51 PM
4theboy's Avatar
4theboy
Does the battery pass a load test? Same thing just happened to me. My battery was actually on a tender showing fully charged. Tried to start car and completely dead. Newer battery. Took battery out and resting voltage was 12.65V, but under load it was toast.
Old Sep 24, 2021 | 04:24 PM
rrwirsi's Avatar
rrwirsi
Before replacing anything, spray the inside of ignition switch with electrical spray such as CRC Mass Air Flow Sensor Cleaner, clean your key, and try your second key. I had a similar problem 4+ years ago, did the cleaning routine and had no further problems. BTW, the spraying the ignition is a semi annual maintence.
Old Sep 24, 2021 | 04:27 PM
Moved to C5 Tech.
Old Sep 24, 2021 | 05:29 PM
claysmoker's Avatar
claysmoker
Thanks for the tip! Will give it a shot and see.
Old Sep 24, 2021 | 07:55 PM
mmartinez's Avatar
mmartinez
Could be something as simple as loose battery terminals, make sure they're snug.
Old Sep 24, 2021 | 10:16 PM
claysmoker's Avatar
claysmoker
Found the problem. The screw holding the negative battery cable was stripped. It turns out the screw was a lot shorter than it should have been when I replaced the battery last year and I wasn't paying attention. When I checked for them being tight today it twisted out when I tightened it. Replaced it and all good now.
Thanks for everyone's responses.
To Help! 2002 is stone dead.
