4L60E transmission fluid re-fill
Old Sep 29, 2021 | 05:27 PM
bobschatter's Avatar
bobschatter
Default 4L60E transmission fluid re-fill
Forgive me in advance for asking such a newb question but...I am familiar with the procedure for replacing the automatic transmission fluid but when the phrase "car must be level" is used are they referring to the car being level as when it sits on the ground (17" F/18"R tires) or is it making sure the pan is level to a level parallel surface (i.e. the garage floor)? Thanks. And I don't mind some mild ribbing for the question.
Old Sep 29, 2021 | 07:38 PM
Smoken1's Avatar
Smoken1
I've done mine on my Quick jack and it sits level on the concrete floor
Old Sep 29, 2021 | 07:45 PM
pjdbm's Avatar
pjdbm
It has to be level on whatever lifting source you use.
I used a magnetic level to get this right
Old Sep 29, 2021 | 09:21 PM
bobschatter
Thought so. I dropped the pan and did a new filter and fluid about 3 years ago without issue. It.s up on set of 4 RhinoGear Rhino Ramps (16K lb capacity) in the garage so it's "level". Just checking...thinking too hard. But the reason it was on ramps was slipping 1-2 gear and hitting rev limiter. All the other gears were fine. Turns out when I dropped the 1-2 accumulator the GM plastic piston was cracked.
To 4L60E transmission fluid re-fill
