Break problema
Old Oct 3, 2021 | 01:01 AM
gerardos8's Avatar
gerardos8
4th Gear
Default Break problema
My break booster went out and I replaced Both Brel and master cylinder .. a booster at autozone and a master cylinder at oreilly.. ever since I replaced my breaks tent to lock up when the car heats up I had a mechanic blead the system and still no change also booster has no adjustment on it .. please anyone with any suggestions I would appreciate it. Thank you
Old Oct 3, 2021 | 03:46 AM
MrMcE's Avatar
MrMcE
Wheel bearings, Active Handling system fail, busted calipers or stuck pins, could be many things. I would first try turning off active handling then seeing if the issue shows up. Hold down the button for 5? seconds I think it is.
Old Oct 3, 2021 | 08:19 AM
Moved to C5 Tech.
Old Oct 3, 2021 | 01:17 PM
grinder11's Avatar
grinder11
While stopped, at least on the '97-'00 models.....
To Break problema
