Grounding Problems
Old Oct 7, 2021 | 02:17 PM
SteveBougon's Avatar
SteveBougon
Default Grounding Problems
I have read several threads on this forum and others, about the problems that corrosion can cause with codes, charging etc, specifically for the connector plugs on G101 and G102 located behind the Headlight buckets.
Since these connectors consolidate 5 or 6 wires into one terminal, wouldn't it be more effective, to do away with the connector, and create a more direct connection to ground?
I'm considering this and would love to hear other's opinions.
Old Oct 7, 2021 | 04:39 PM
rrwirsi's Avatar
rrwirsi
And do not drive in the rain. The stupid designers put many of the ground connection points accessible moister not to mention the idiot design of the connectors.
