C5 Long Cranking and Fuel Code
Old Oct 10, 2021 | 12:22 AM
LS147's Avatar
LS147
Default C5 Long Cranking and Fuel Code
I recently acquired a 2002 C5 base M6 with 3800 miles and it has 2 issues I do not know much about. First, it started throwing P1431 code, sending fuel gage to empty and lighting up the check gages light. I reset the code and the fuel gage drops to whatever amount of fuel the tank has at the moment but doesn't move after that until I reset the code again when it reappears. Next it also has a hard time starting, requiring cranking for at least 4-5 seconds and even then it still does not start sometimes. When it finally does start, it sometimes holds the revs at about 500 rpm for 2-3 seconds and then idles like normal. Car does not stall, seems to have no issues once running and is only throwing P1431. I have driven it about 1000 miles since I got it a couple days ago and have been filling up with Shell gas. I have also used two doses of Techron. Any help is appreciated.
Old Oct 10, 2021 | 07:51 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
3800 miles ??…looks like the car was only driven to church on Sundays !!…I don’t know what part of the country you’re in but I would fill up with “non ethanol” fuel if you can find it and wait till the fuel tank is running on fumes or at least a 1/4 tank before adding some Techron…the DTC is your right tank so if you add it to the fuel when you are more than 1/2 tank it’s not going to make it to that right tank !!…as far as the hard starting it may be a failing cam sensor…also when the fuel tank feed line loses its prime due to a leaky injector or a few other things the car may take longer to start….usually if it sits overnight…if is it hard to start after it sits cycle the key on and off a few times on that initial startup to prime the fuel system….every time you turn the key on you should hear the pump turn on for 2 seconds then shut off…if you can buy a fuel pressure gauge that may help…the starting issue may be a little harder to diagnose correctly than the P1431. Also a TSB was issued in 2003 regarding the fuel gauge…a PCM update would be required but I would try the other thing first based on the low mileage of the car. Also a good idea to fill out your profile with model year, mods, tune etc…this is especially true with electrical issues since there are slight differences year to year with wiring !!
