Steering wheel vibration issue
Old Oct 13, 2021 | 03:38 AM
Loges20's Avatar
Loges20
3rd Gear
Default Steering wheel vibration issue
So at first I got all my tires balanced. Tireman said my front left rim was bent. I replaced my rims (they were rough looking anyways) and got new front tires. Vibration starts at around 50 mph and gradually gets worse the faster I go. I can go 85 and it will vibrate but it’s not so horrible that it feels like the wheels are gonna fall off. It feels like it could be coming from the front. I’ve put probably 3000 highway miles with the bent rim never going more than 75.
Old Oct 13, 2021 | 10:35 AM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
Have your wheels/tires road forced balanced. You could have a bad tire, or perhaps even a bad rim. Road Force Balancing will show the issue.
Old Oct 13, 2021 | 12:28 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I agree that the first step is a road force balance. Also make sure that your tires are not overinflated. If that doesn't fix the issue, you might need an alignment.
Old Oct 13, 2021 | 12:50 PM
1wholikescars's Avatar
1wholikescars
I'd also consider that your upper and/or lower control arms need to be replaced (or at least the bushings). A worn bushing can easily cause this. I had the vibration in the steering wheel issue and controls arms plus new alignment afterwards fixed it.
Old Oct 14, 2021 | 10:47 AM
Moved to C5 Tech.
To Steering wheel vibration issue
