Tune- normal driving mode vs comp mode
Old Oct 24, 2021 | 10:28 PM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
Default Tune- normal driving mode vs comp mode
My car is professionally road tuned. It's an 03 base with full exhaust and a vararam intake. It drives great on normal driving mode but if I switch to competitive driving mode or traction control off mode it seems as though the tune is no longer applied. When I change modes, the instant throttle response is completely gone and the car is just lethargic. When switched back to normal mode it's great again.
Does anyone know what this is all about?
Old Oct 25, 2021 | 09:10 AM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
Old Oct 25, 2021 | 10:37 PM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
Old Oct 25, 2021 | 11:55 PM
RonSSNova's Avatar
RonSSNova
There are only a couple tables in the tune that deal with traction control when it’s on.
They are timing tables.
I can’t imagine how turning TC off would have anything to do with the tune. At all.
So something else going on. Maybe it’s applying the brakes somehow.
Old Oct 26, 2021 | 09:32 PM
Ed Ramberger's Avatar
Ed Ramberger
I believe there are throttle progressivity tables that are affected in those modes. I have seen it noted in several threads. I believe EFI Live can show the table. It would appear that the tuner did not address the throttle tables in the other modes.
Old Oct 26, 2021 | 11:26 PM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
I had suspected it would be something along these lines, and was hoping someone would know what it really was. Thank you.
Old Feb 14, 2022 | 07:59 PM
Ed Ramberger
Did you ever do anything about this or talk to the tuner? Curious to see where you landed.
Old Feb 14, 2022 | 11:47 PM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
Yes i did. I reached out to my tuner and he checked my file. Turns out the tune had only been applied to normal driving mode. None of the tables got carried over to the comp mode or traction control off mode.
He of course offered to ammend it free of charge.
Problem solved.
Old Feb 15, 2022 | 01:52 PM
imma_stocker's Avatar
imma_stocker
Interesting, so these cars can have slightly different tunes depending on driving mode? Wonder if they can be used for fuel type or activating nitrous.
Normal setting with sleeper tune and kill mode in competition would be nice.
Old Feb 15, 2022 | 11:16 PM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
Seems like it could work. If so, you could press the button for a tune with pulled timing for a nitrous run.
Old Feb 20, 2022 | 10:39 PM
RonSSNova's Avatar
RonSSNova
Never heard of this. I tuned my car, works the same no matter which driving mode.
Old Feb 21, 2022 | 01:25 PM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
Im just relaying what my tuner told me. They are one of the most reputable tuners in the entire country so if they say it, i believe it.
Old Feb 21, 2022 | 02:38 PM
Justin Raney's Avatar
Justin Raney
Would you happen to know if theres different tune tables in sport, touring, normal or whatever the 3 dial switch is. I thought it was just for the shock stiffness on f45 equipped vehicles and doesnt alter the pcm just the shock compression? Mine is a 99 but they dont adjust as i have regular 97-13 new base c5 c6 shocks without the sensor valve option.
Are you talking about competition mode on the traction control button where you hold it down for 5 seconds?
Old Feb 21, 2022 | 11:19 PM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
I cant tell you if the suspension switch changes anything because my car has the base FE1 (soft) suspension. I was in fact referring to the activation of the comp mode via holding the traction control button for 5 seconds.
Old Feb 22, 2022 | 09:35 AM
Justin Raney
I don't think my 99 has comp mode. I tried holding the switch 5 seconds just either traction control on/off.
Old Feb 22, 2022 | 03:38 PM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
I dont think comp mode came along until 2001. Either way the older models didn't have it .
Old Feb 22, 2022 | 07:47 PM
RonSSNova's Avatar
RonSSNova
My 2000 has competition mode
To Tune- normal driving mode vs comp mode
Old Feb 22, 2022 | 09:51 PM
Johnny Hardcore's Avatar
Johnny Hardcore
All three of my 99s had it. Your car needs to have the active handling option code JL4. It came out as an option in 1998-1/2 models.
You need to be at a full stop in order for it to engage pre 2001. The 01's plus you can engage Competive Driving on the move.
Pressing the active handling button once (at any time, even if car is in motion) disables traction control and stability control. Holding the active handling button down at a full stop you will see "Competitive Driving" come up on the DIC. Which disables only traction control but keeps stability control engaged.
It has nothing to do with the F45 or F55 adjustable suspensions..
Old Feb 22, 2022 | 09:53 PM
Johnny Hardcore
Not accurate. See my previous post.
Old Feb 22, 2022 | 10:42 PM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
Noted, thanks for confirming.
